I feel like a guinea pig lately, with great lights randomly going into nuclear-mode & failing when i go to bed… i fear one night, a flashlight will go bad and burn me to death in my sleep…
Does the use of glow discs, glow powders or tapes in the emitter/lens cavity affect the beam tint of the actual light? Also, do tritium tubes in the optics affect the beam tint?
Aux lights even placed close to the main emitters cut off when the main emitters are engaged, I have 6 lights with these and they do not seem to affect the beam tint. I don’t have any of the initially questioned color enhancement options, that is why I am asking. Thanks!
Looks like the thinnest area of the switch trace burnt. I’d guess the switch connection shorted with b+ (?) Such that you had the full short current going through that tiny trace. That might explain the fact it was ramping on its own. I could well be wrong though, I haven’t really looked into the details of how it all works.
Its possible. i had a closer look this morning with a magnifying glass and it looks like that trace is now melted & stuck to the spring.
EDIT-UPDATE: ok after closer inspection, there is no doubt the small trace had melted to the tail spring, why it happened after a small fall off the night table is a mystery.
Probably hit the floor tail first with the impact causing the spring to pierce the mask, switch on, ramp up then the trace acted like a fuse with the current overload. Interesting.
That was my first thought as well. Surely the energy would not travel both directions along that trace. It seems only half the trace should be burnt, probably the outer half from the spring. I suspect there was a short in the inner tube to the outer tube which caused a lot of amperage to flow all the way across that little trace. The fact that the urnt trace got stuck to the spring seems almost like and after effect than it is a cause. IDK, what do you guys think?
To me it looks like high current flowed through the inner tube when it normally would only see very low current.
Neal responded quickly and sending a replacement fortunately. What i will do however on the replacement is remove the spring, and resolder it rotated a little, so that the end of the bottom spring creates a open gap over that trace to prevent the spring from breaking the coating and shorting to that trace if that is what happened then it hit the floor, (which is what probably happened as CRX mentioned, the impact of landing tail cap down probably caused the short. its an easy fix to prevent it from happening in the future, and will show a photo of the mod/fix when i receive it.
So, is this a general design flaw of the light? Is it likely to happen with a drop that hits tail-first? Or is this a case where that light had a manufacturing flaw, and it’s not likely to happen in other lights?
I think its a matter of everyone checking the tail cap board spring, to see if theirs is soldered in the position where the spring is touching that trace or of its positioned with the spring gap over the trace. (the one i had the spring was soldered with its bottom edge directly against that small trace that crosses under it, and the spring end-gap was to the right of the trace.
I’m not sure you understand. All versions have the trace go under the spring. That is not an issue. If the sharp (cut end) of the spring is directly over the trace and it’s soldered in such a way that it’s pressing directly against the trace, then a heavy blow might push it through the solder mask and make contact.
Your light in the picture looks fine. I see no chance of the spring ever touching the trace.
Den, I’m sorry to hear about your light’s failure. I’m glad you’re okay and that Neal is taking care of a replacement.
My spring is resting on the board in the area of the trace. A piece of paper won’t fit between the spring and PCB.
With the trace and FW3A label positioned at 6 o’clock, the end of my spring is soldered to the pad directly to the right, between the 4 and 5 o’clock position.
This places the ‘gap’ between the 1 and 2 o’clock position.
I plan to rotate the spring when I get back to my soldering iron.
I assume (perhaps incorrectly) that springs tend to be installed so that the ‘end’ is on a pad and connected with solder.
