Looks a lot different above the TIRs. Pretty cool
Sweet!
Its seems that there is a little mistake on this protrotype with the AUX LEDs colors order on the external ring. It looks better like on the inner ring when yellow is placed between green and red. Pretty sure you already noticed it but worth mentionning to be sure.
its warm white not yellow, camera does not show it right
I measured my XP-L HI 4000k at 10,600 lumens at 1s with my TA lumen sphere calibrated with Maukka lights using VTC5D fresh off the charger. A bit disappointed with the output since the 7-emitter E07 makes 7,000 lumens at 1s, but the tint is very nice. The top of ramp is set the same as turbo so double click from off takes it directly to turbo. Typical Anduril lights sets the top of ramp at about 50% or so of turbo.
Does anyone else have the XP-L Hi version? I’m curious is the XP-L HI version dimmer than the SST-20 version. My M43 with XP-L HI 5D was 1,000 lumens lower than the XP-G2 5D version.
EDIT: I just realize one of the batteries was a Sofirn 2200mah and not the VTC5D. I remeasured using 3x VTC5D and got 12,400 lumens at 1s. Better but still less than what I expected.
I just took a tint measurement at turbo and got this:
CCT: 4137K
DUV: –0.0024
CRI (Ra): 73.1
R9: –18.5
Rf: 70
Rg: 97
Ra: 73.1
5D is still one of my favorite tint. Looks very perfect neutral white at night time with no hint of yellow when my eyes are adjusted to the 2700K-3000K house lights.
What did you end up getting for measuring tint/CRI?
Sekonic C-800
Does anyone know what the sustainable output is on this light?
Starting @ 14k lumens for the 5000k, what will it drop to but hold? 5k lumens?
~2,000 probably based on the charts in the OP
Photos don’t attach for some reason.
Got a aux LED board from Lexel and got it to work after 6 hours of struggling.
You don’t want to let anyone know what you learned?
Here you go.
I was tired last night and just wanted to share my results.
The + goes to I+ on the driver, the - goes to G. I tried to bridge R4 but I believe it may be possible to solder the + directly to the furthest pad of R4 (from I+) and have it work.
The steps for replicating my mod are:
1. Disassemble the front of head- remove optics, desolder the big red/black wires connected to the mpcb that poke through the middle hole from the driver
2. Remove reverse polarity protection ring by prying and then unscrew the driver.
3. Solder wires to the lighted board/your aux led. Solder those wires through the hole in the mpcb shelf and to the board in the aforementioned positions. Leave a couple inches of wire. (Too much and you’ll have to cram the wires in later, too little and they’ll be too short)
Test everything!
4. Pull the two original thick cables through the mpcb hole. I did this buy soldering a thin wire to the tips of both thick wires to help me pull them through. I can draw a diagram if someone wants it (send me a pm).
Test everything!
5. Reassemble everything.
Subscribed
There is an easy way to subscribe without making a post. Just look at the bottom of post #1. There is a button you can click.
I want to update Anduril on my D18. This red ring that covers the screws is glued or what?
Yeah, it’s glued. I pried mine off with the back end of a nail so I could remove the retaining screws and the driver.
It’s also pretty inconvenient to take out the optics and unsolder the MCPCB wires before reflashing, so I almost never do it. I hope if there’s ever an updated version, it’ll have convenient reflashing access.
My buddy says he is going to gift me his D18, the one I swapped in LH351D’s, so I will have the entire Intl-Outdoor collection. He says it can sit over here gathering dust as easily as at his place. Lol
Who knows, I might actually put it to use!
Lately my favorite way to use soup-can flooders is to remove the optics so it runs in mule mode, then ceiling-bounce it for photo fill lighting. I only run it at ~6000 lumens for a few seconds per shot, but it sure is handy having so much omnidirectional light to eliminate the shadows.
Here are a couple shots taken that way, at night, with a single flashlight as the only light source. I just grabbed a couple random items to use for test shots:
Just wondering how many people have measured the lumens of their D18s, perhaps with SSTs?
In my quasi-calibrated sphere I get 15-18k lumens depending on the cells I use (brand new VTC6 and 30Q or older VTC6) with mine which has 5000k SST-20s.
The VTC6 are clearly more powerful but just wondering if it’s likely this light is putting out slightly more than the claimed 14k.
Absolutely in love with this light. Insane output in a lovely compact form factor and terrific build quality.
