Stonewashed Ti looks cheap and ugly and ruins a damn fine material (except for heat transfer though).
Leave this bad idea to cheap knives manufacturers.
This is your personal preference/opinion, which is fine. But it does not necessarily reflect a general consensus. People like raw, polished, stonewashed, & bead/sand blasted Titanium. Personally, I like stonewashed & bead/sand blasted. It beautifies it & adds character as far as I am concerned.
… Many knife makers/manufacturers stonewash or bead/sand blast the Ti handles on their knives. CRK is a prime example, and his knives are not exactly cheap.
I just got my copper fw3c. Decided to change the 5a to sst-20. One of the legs of the new style optic is cut off shorter than the other The messed up thing is their is a small Phillip screw taking up the space for the missing portion of leg. Who’s the genius that came up with this idea?
That’s not how it’s supposed to work. Sounds like yours was installed wrong.
The Phillips screw is designed to sit in divot drilled partway through the underside of the star. It is NOT supposed to sit in one of the holes for the legs. All 3 legs on my copper FW3C are fully intact.
I asked in the interest list but the discussion is probably better suited here. I personally like bead blasted titanium, what’s the difference between stonewashed and bead blasted finishes?
I haven’t heard anything about either one recently. Neal at least looked through off-the-shelf diffusers to try to find a compatible one, but failed. I tried to tell him in advance that they don’t exist and would need to be manufactured, but maybe that’s enough of a hurdle to keep it from happening.
I don’t have access to the numbers, but if it helps at all, I’ve heard the BLF-A6 has sold well into the five digit range… and I’m guessing the FW3A may end up being more popular than that in the long run.
I don’t think I’ve tried a new one yet. I hope it’s not as bad as it sounds.
It was an old prototype from 2018. It doesn’t really represent how the production version will be.
The differences I’m aware of are:
2018 proto was bead-blasted, production is smooth polished.
2018 proto parts didn’t fit together right, so it’s hard to get the thing to turn on at all, and the clip doesn’t fit.
Otherwise though, I guess it should be pretty similar. It’s just like the aluminum FW3A, except made from copper and polished to make it shine. And it’ll be heavier when empty than the aluminum version is with a cell installed.
I named my prototype Wilbert Stinkyhands, in case that helps with using the search function.
Nope, that one was apparently solid copper and the photo was taken with a really misleading white balance.
I hope my experience will be the same, if I ever get a SST-20 model. I think the purple one is supposed to use those, maybe.
If I understand correctly, the items currently shipping use the 05-22 firmware, which was one revision before manual memory was added. They made the drivers like half a week before the firmware got updated.
But it should be in the next batch of drivers, whenever that is. Maybe in another couple months?
It looks like, for that to happen, there would need to be two shorts — one where the outer tube makes contact with the switch contact ring, and one where the spring scratches through the solder mask to contact the trace shown in your photo.
If both of those happened, it could bypass the usual BAT- path and send all that current through a single small trace instead, which could cause it to burn. But it’s pretty strange that the spring would make contact with the trace. It’s generally held up a bit by solder, and the trace is underneath an insulating mask. Basically, it sounds like very bad luck.
Making contact between the outer tube and the switch ring is much more common though. With the tailcap parts so loose, the PCB can get off-center and touch the wrong parts. But normally this only makes it think the button is being pressed. The bulk of the current still flows through the correct path in that case.
This material always seems divisive. On the one hand, it gives a soft velvety feel with slightly better grip than a smooth metal. On the other hand, it gets visible scratches (or “snail trails”) really easily so the surface doesn’t look new for very long.
I’m fairly happy with the bead-blasted copper prototype though, after forcing a patina and polishing it. Most of the blasted texture is gone now, so it mostly just feels like regular non-blasted copper.
It’s not back luck, it’s bad soldering that lumintop is doing. Mine had the pointy bit of the spring almost touching the trace. It was also an awful soldering job, with the spring way off center and only held on in one spot. I resoldered things to make it safer, after reading about the incident.
I suggest everybody check their spring soldering. Most are probably fine, but it’s random.
[/quote]
I don’t mean bad luck in the sense of what happened when it fell. I mean bad luck in the sense of getting an item which was assembled badly — being the unlucky person who got a dud.
If this was happening frequently, that wouldn’t be luck… it’d be a broken manufacturing process. But there’s only one known case of this happening, and one (yours) which looks like it could have been a near miss. So unless more people run into the same issue, I’d consider it a “ask vendor to send new hardware” sort of issue instead of a “ask manufacturer to fix their process” sort of issue.
