however, after moonlight, I do NOT want High, nor Medium, which is what the Folomov will do Unless I remember to turn it off in Low
IF moonlight was able to be memorized, that would prevent the Folomov UI from jumping from moon to Medium or High
with the Olight UI, regardless what the last mode was, IF I use the shortcut to moonlight, the next mode will Always be Low. Without any need to prememorize Low, that the Folomov Requires
basically, the Folomov UI is totally UNpredictable. I never know what level it will jump to after moonlight, since I dont always remember to turn it off on Low first.
I HATE the Folomov memory because it does not do LMH after moonlight
I Love the Olight UI, because it Always goes to Low after moonlight, as it should be.
And, the Olight UI has the same shortcut to moonlight as Folomov, PLUS the Olight UI Does memorize moonlight.
The poor UI sounds disappointing to an otherwise unique light. I just keep thinking something like a triple E21A in something like an S2+ shorty would be pretty sweet.
3000k is a great fully dark adapted Color Temperature and works great on the nightstand for bathroom runs. fwiw 3000k is the same CCT as the incandescent bulbs in my house.
I put a very high priority on the High CRI, enough to tolerate the UI
in fact, I hate the Low CRI of the Olights so much, that I would buy the Folomov over the Olight, for the LED alone.
but I would not EDC 3000k during the day, its just too warm (yellow), and dim looking, when my brain is adapted to daylight.
Olight tints have sucked for so long itās reason to utterly dismiss the entire brand .
They made interesting looking lights and just shot themselves in the foot as far as tint. Olight has to be giving lights away for me to even begin to look their direction .
You've said this numbers of times but I never understood the logic behind this .
Why is anyone using a flashlight during the day ? If you do it's for a micro second to find a eraser dropped behind the desk .Who cares about tint or cri in the daytime .
you dont use a flashlight when you change the oil on your car during the day?
you dont look under the dash or seat or in the glovebox or trunk of your car during the day?
you dont need more light when looking for something in a closet, garage, cabinet, or box, during the day?
you dont go into a dark basement, or attic, or look into dark corners during the day?
you dont need to light a pilot light on a water heater or oven, or furnace, during the day?
Does Your lifestyle offer no need, or opportunity to use a light during the day?
I recommend using a flashlight color temperature that is equal to or cooler than the ambient light that your brain is adapted to, whether during the day or during the night.
daylight has a color temperature of 5000k or more
so does most workshop, office, gas station, warehouse, and home LED lighting.
Using a 3000k source when the brain is adapted to 5000k +, will make the 3000k source look dim, yellow, or orange.
otoh, in full darkness, 3000k is very pleasant, and relaxing. I have several lights with 3000k LEDsā¦ their main use is camping, and nightstand. I try to use them during the day, but they keep getting bumped out of my pocket by cooler LEDs that look whiter and brighter when my brain is adapted to 5000k ambient light sources.
I donāt have any issues with the clip. What do you find it lacking? I havenāt watched your video.
I agree about the too-easily activated switch. I lock mine out by loosening the tail cap a bit, if carrying it somewhere other than clipped to my shirt pocket.
It just felt too loose and thin, like it folds back too easily. It works okay as a pocket clip when the light is inside the pocket, but I kept it on my belt while testing it. It would come off almost daily from things like my jacket, bag or chair brushing it. I usually carry an Olight S1R II, and that thing just stays on until I want to take it off (most of the time). I would have preferred it to be slightly thicker, and with a bit more retention.
All of my lights are clipped inside pockets, except for an 18650 right angle zoomie, which is clipped to my belt. Itās came off several times, but itās so big that I usually hear it hit the ground / floor.
