Very nice build. I like the 9900k but I early adopted Ryzen upon release and have had zero problems for the past 2 years. I will stick with Ryzen for my next build but there is nothing wrong with the intel since it meshes so nice with nvidia. I’ll probably go all red and navi just to stick it to the man.
Solid setup. I am sure you will enjoy it.
By the way, what games do you usually spend your time on ?
Congrats for your new PC.
However… I wonder why your old machine suffers from lag in YT videos. I have many pc´s much much older that your old one and none of them have any lag in YT videos. Maybe because I dont see the videos in HD, just 360 resolution
If I hadn’t the issues with my old Laptop I would have gotten a 3900X in 4-6 months, maybe even 3950X
In most cases those 4 or 8 more cores are not used, and I am not planning to do heavily rendering of Videos or 3D stuff so 8 Cores 16 Threads is enough
even the 9900K gives me about 2.5 times more speed than the old 4 Core had, the graphics card almost 3 times more
I have ordered this system almost 2 weeks ago
I had to spent now 2.5 hours drive to the PC shop, because they messed up and put all the extra parts, software etc. to another customers PC (which was luckily not already shipped), so I could exchange everything in my box without waiting 2 times for shipping forth and back
Sure AMDs 7nm process gives them a big advantage in the next 18-24 months
till Intel get also 7nm CPUs, they may even skip 10nm at all which they planned to get 2016 running
also many programs support heavily GPU rendering which is a lot more efficient than CPU, so I won’t miss those 4 cores I could have got later
for all of them around 100€, they have the latest aerodynamic optimization and have 6 years guarantee
I made some slight changes, added SATA data cables for HDDs on the cable management side
The worker tested the PC after he had the right spacer for it, I told him the front Fans are too loud not throttling down, he showed me where to do in Bios the fan control, but at home I see those fans are recognized as AIO pump and you cant configure it to fan
Congrats on the new PC, always satisfying to make those big jumps in CPU generations.
Bought one last year to replace my 2012 one, and probably not going to change before DDR5 is here, even if i really want to reward AMD now for bringing competition back to the CPU and GPU market.
I built my PC with a similar case and high quality fans. I really like them but they do need setting up in bios to really take advantage of them being quiet and make use of 4 pin/PWM.
http://www.phanteks.com/PH-F140XP.html
The air filters and sound dampening of this case are really good
yes the ROG Bios are nice, you can even set the fan to the lowest RPM which is around 300 up to 50°C core temperature
on paper, I have 280m³/h at 1500rpm pushing into the case, I know with filter fan grill etc it will be half that value, you can hear them at full speed, but at lowest PWM they are almost not to hear if its not dead quiet in your room and you are pretty close
Maybe it’s a bit overkill, but I decided against an AIO for the CPU, they tend to fail a lot compared to good fans
and finally I have now 4 fans around the CPU
two 120mm 1200 RPM PWM Noctua
- one as back case fan
- the other is mounted 90° to that case fan venting through the top, also gives a nice flow above the top CPU voltage cooling block
CPU cooler was from the shop that build the PC a BeQuiet! Dark Rock 4 which is one of the biggest you can fit in the case
it has the 135mm stock Be quiet! fan, but I do not like that it is quite far away from the cooler having two 2mm thick rubber straps on the fins
- I added a 2000rpm Noctua which has a quite high static pressure
too bad I can only mount it on the pull side, but this will get in hot weather like last weeks enough, and due to drastically new design with less air gap around the blades and spiral form its quieter than the 140mm at 1500rpm, and still
The total system price is definitely not cheap
1694€ for the PC, its build by a company and I have 3 years guarantee on it, I could have saved a bit buying all the components but there is always a risk you end up in a support trap if something fails
- CPU and graphics card alone cost a bit over 1,000€
- 72€ 2. 16GB RAM module
- 134€ Samsung 970 pro M.2 PCIE with NVME
- 1TB Samsung Evo 860 from my old Laptop
- 93€ 4TB Seagate Barracuda for internal Backup, I got also a 4-year external 4TB but I want fast drive inside for easy backup, and an older drive is more risky to fail
- 40.99€ 2 140mm Case fans
- 27€ the 2 120mm 1300rpm Noctua Redux, I simply transplanted the rubber edges from the 120mm CPU fan
- 28€ CPU fan I used the included rubber band that goes all around the frame
- 6€ some more pull through rubber mounts as the normal ones are hard to mount in the back side
so bottom line I get a bit over 2,000€ for that PC, so its not cheap but very solid, quiet and powerful
I still think you got an excellent price. It has been a while since I’ve priced anything. But in the past, I’ve seen online custom build shops charge more than that for a much lesser machine built.
Something is seriously messed up then. I have a 7-year-old Lenovo laptop with i5 CPU which cost around $800 back then, and it still plays youtube videos just fine under Windows 7.
You can use msi afterburner for fan control.
I have repaired out of need.
I’ve never upgraded from need.
Regarding the premature demise of the $1500 4 year old laptop, I don’t think it’s a software issue, it seems more like a cooling issue where the system can’t dump enough heat and downclocks itself , suggesting part of the cooling system has failed . If you open it up, blow out the dust, check that the fans work, then refresh the TIM, thermal pads, and consider copper shims where appropriate it should perform more like it did previously if not better. It could easily be something as simple as fluff blocking an intake so maybe with a bit of work this system could be restored to functional use.
As for Windows 10 support, that should also be good on a reasonably high end laptop made in the last 4 years - my partners Lenovo is much older yet has Windows 10 drivers - *nix support should be fairly good as well. If you can’t find drivers for that specific model, a good tip is to look for enterprise grade systems built around the same time as they are often contractually required to support those for much longer than consumer systems, and they often use compatible drivers.
I blow out every year the coolers with compressed air of my laptops, I did it like a month ago when problems started, but it didn’t help, the fans run and move a decent amount of air and heat
I will put the original saved OS backup over the SDD when I am finished with moving, and then will do stress test with Prime95 and GPU benchmark to see if it is still bad
I had also in the past 4 years on my Laptops
- 2 times the graphics card replaced under guarantee (DELL and XMG)
- I gave my 2. last Laptop 2000$ to my dad when it was also about 3 years old, but it simply died by main board failure when he had it less than a year, I sold the SSD, CPU and Ram for like 250 bucks, graphics card was a fast NVIDIA but integrated in the main board
This is mainly the reason I am going back to desktop PC, you can replace dead components
-single core IPC of new Ryzen is acceptable now, not too far from intel, i doubt that you will notice this difference in daily using
in gaming, some latest benchmarks (with latest BIOS. it’s new CPU, so BIOS must be updated to optimize them obviously), show that Ryzen is equal or better than intel
-and to crush Intel CPU, you dont need custom Water Cooling, actually you can use stock fan, it’s much better than the intel one
Also pushing the 12 core to the performance in the crushing Intel reviews you need a serious water cooling and pump 50% more power in the CPU overclocked
i believe this is not true
IPC is actually better than Intel now.
Was about the same with Zen and Zen+.
AMD just needs a bit of a clock speed boost, and every victory is achieved.
And I have to agree on the cooler front.
The CPU is very efficient, even the 12 core one. It’s actually the mobos consuming a lot of power.
It is except in gaming workloads, hardware unboxed tested 9900k vs 3700x at 4 GHz.
I’ve seen that air cooling matches if not outperforms aio coolers. I might go noctua on my next build.
