AAA.
I also like AA but consider that medium sized.
I don’t normally need big lumens from smaller lights. So I prefer nimh for availability, cost, and stability.
AAA.
x2
I had a dream about an AAA size RRT-01 with LVP, then I woke up to my Phat TCR-1 with an unprotected 18350…
The perfect light is a combination of features, none of which exist in any one model.
Same as Women.
I like to have more than one.
Does Size Matter?
from shortest to longest:
short and skinny: ET 16340 2.9”
longer and fatter: RRT-01 18350 3.2”
long and skinny: ET AA 3.4”
Four of my favorite small cell pocket lights.
LAN Mokume Gane XP-L HI 5000K, 14500, Electronic Tail Switch.
FourSevens Atom XHP50.2 3v 2A, 16340, Reverse Clicky Tail Switch.
CRX CuTi Zoomie KW CSLNM1.TG, 18350, Forward Clicky Switch.
CRX Rotary XP-L-HI 5000K, 18350, Rotary Lighted Tail Switch.
Definitely 14500
14500 for the same reason as everyone else - slim. I would’ve thought 18350 got more votes for drain rate and capacity but there you go…
14500 lights are my choice. I like the slim profile.
14500. Because its slim and the ability to swap out with a AA.
For the last few years, it’s been the EagleTac 2014 D-25 25 ti. clickly.
Chris
Ah, I thought they were all AAs.
I am looking for a really slim AA zoomie and this looked like one.
For the last few years, it’s been the EagleTac 2014 D-25 25 ti. clickly. Chris
Yep as a clicky the eagle tac and the xeno es1 are the same size (small and thin ) Eagle tac takes either battery and the xeno only wants the AA..The old Eastwood / blf light modded with a nichia is still a very small nifty lil clicky.
In a twisty the old Thrunite T-10 and the jet beam are nice and small too .
Still love a plain old nichia 219B Lumintop tool at only 20 grams with a battery it's often found clipped to my collar .
Nice part of having lots of lights is they are what they are and if weight is an issue than leave it on the shelf . I still love some AA lights that are bigger than some 18650 lights ....just not all the time .
Don't need to bring a gun to a knife fight
I prefer the 14500 format because most of them can run also with regular AA battery.
i would say 16340 for me then, seems to be my fav i would have to vote.
Among these three, 18350 for sure. For me, capacity is everything, and it’s one reason why I have two 16340 torches and hate both of them.
But for real, I won’t go below 18650 and don’t plan to change that opinion anytime soon.
I agree.
18350 for capacity, but I don't even use those because 18650 cells have the most capacity per volume.
(Except for maybe 21700 cells.)
I agree.
18350 for capacity, but I don’t even use those because 18650 cells have the most capacity per volume.
That and 18650 is just a nice compact format for a dude of my size. The heft and bulk are just enough to be noticeable without being overbearing.
Haven’t tried a 21700 yet, it’s a bit too exotic (so few options for lights on the platform) and expensive for my tastes, and the torches that fit it don’t have runtimes that seem to take enough advantage of its mAh like 18650 ones do. Maybe when it’s more mainstream and more picks are available on the market, I’ll pick one.
I feel the same about 21700 cells.
Not many choices so far, though it's probably the cell of the future.
There are other types of batteries, not as famous as the ones that have been talked above, that may deserve an attention, namely 18500 and 16650.
For the first, it shorter than 18650, has less capacity than those, but has more capacity than a 18350, being slightly bigger.
Emisar D4, Jaxman, and few more lights use it (stock, not modded).
For the second type, I only knew it some time ago when I started messing with my On The Road i3 and M1. Together I can make them use a 16650 battery.
Recently, I also saw that 4Sevens (by Prometheus Lights, aka Jason Hui) will also launch a 16650 flashlight:
Prometheus is the new home of Foursevens ! If you missed the acquisition announcement you can read about it in this >> link << Legacy Foursevens Warranty Information: Please check the warranty page for...
Not too large, longer than a AA light, with capacity around 2200mAh, being this more than 14500/16340/18350.
Although these are different types of batteries, they can be considered for EDC use for sure!!
For me, the most compact 18650 lights are very hard to argue with. They compete with the more typically-sized 14500/18350 lights, and are easily small enough for me to carry daily. I can tolerate a maximum size of a Convoy S2+, though lately I've favored my smaller lights much more heavily.
If we're going to talk about the smallest examples of each battery-type light, I actually rather like the 16340. It is thinner than 18350 and shorter than 14500, so super pocketable. In fact my D25C Ti is not as small as a 16340 light could be made, but because it's 16340 it is so easy to carry. I compare it to my AA/14500 lights (of which I admittedly have very few) and I don't want to switch. I also compare many 14500 lights to my ZL SC62 and then take the Zebralight. It does compactness just that little bit better than the D4/FW3A.
So, the steps for a compact light:
Olight s1r was my edc for about a year, and I still think the form factor is about perfect. But the battery began to be less than perfect on turbo, and the D4 came out. Now its the D4 with the 18350 tube, but if I could get a nice emitter, Anduril, a vapcell 16340 in my s1r, then I would be back to that for sure. I realize the emitter and vapcell are easy, but not so for Anduril.
