so imagine a LEO and he is using a CW light for Duty at night. does this matter too?
thanks.
Color Temperature (Change Lux)
A lite and easy-to-use addon that adjusts screen color to match your environment!
thanks.
In standarized world there is a term: photobiological safety. Light can have many effects on human body. strenght, wavelenght, PWMs - these all take effect on us.
thanks so I am wondering then if it just best to take cool white out of equation when on duty at night and use neutral warm .
cheers…
Man, I wish my knowledge allow me to give you the right answer. But it does not and since we’re talking about human safety (safety always 1st) I do not dare to answer. But I’m nearly sure some requirements (made upon research) are given in occupational hearth and safety guidelines. (OSHA?)
There’s also a popular program for your PC called f.lux that makes the colors warmer at night time and colder in the day time, which I installed on my PC. It works great.
I thought windows 10 already came stock with the night light filter feature? Pretty much never used them as I kinda sleep early anyway
sorry that has to be bogus.
Hmmmm…so even if color temp is lower, is it possible for hidden blue to be in there?
there is blue light in sunlight… is that causing all these symptoms?
wle
Hmmmm…… I do not pretend to understand either side of this. But it seems not all Blue Light is bad??
My understanding is that blue light specifically is the type of light that impacts the sleep cycle, as opposed to red or green. And for this reason, warmer/cooler CCT lights have different effects. I've easily observed this in my own life: one room of my house has 2700K lighting, and I will fall asleep if I try to read a book in that room. The other areas of my home have 4000K to 5000K lighting, and I have no issues reading and staying awake there.
Anyway, this becomes an issue when significant blue-light invades spaces where it hasn't always been. Cool-CCT streetlights in particular could be an issue, as they shine at night. If people aren't aware of the impacts of blue light on their sleep schedules and/or don't accommodate for that impact in their life, they'll have sleep cycle disruptions. This can range anywhere from decreased quality of sleep to straight-up insomnia. In fact, I had seen studies showing this impact comparing dark vs. brightly lit neighborhoods already (wish I still had that source), and I'm not surprised at all that adding more blue light would strengthen the effect.
My answer is to move into my warmly lit room at the end of the day and wind down there. Also to limit screen usage and/or blue-light filter the screen. And lastly, blackout curtains ;)
TL;DR: It's long been known that light affects sleep, more blue spectrum means stronger impact, and sleep impacts everything else
so how long is the effect supposed to last?
how strong and how blue does it have to be, to remove X minutes of sleep?
wle
The liberal use of the word “may” negates the declaration of a scientific conclusion. H2O “may” be lethal… Circumstances dictate how lethal.
thanks.
It’s like a magic cancer-wand. Point it at a bad guy and bam! Dude dies of cancer, and doesn’t even get to die in his sleep. Teaches him right for lurking around an alley in the dark.
I knew there was a reason why I kept all those crappy LED maglites.
I thought using a cool white for not so long on and off during a night duty LEO shift would be ok as It wasn’t excessive.
not sure, maybe best stick to NW/ Warm
For those concerned and using firefox, opera or chrome without a built in color temp changer, this add on is very handy. It’s not automatic, but just leaving it on all the time isn’t that bad either.
the “blue light” emitted by the LEDs may be disrupting the body’s circadian rhythm, which in turn affects hormone levels.
Both breast and prostate cancers are hormone-related.
The quotes from the article seem to answer a lot of the questions here. The issue is constant, bright, high-CCT street lighting being linked to changes in sleep patterns/hormones.
Maybe I’ll show you some example - from photobiological safety point of view.
The main issue here is a blue light spike at 430-440nm - it’s caused by a phosphor coating quality and phosphor’s mix.
As you can see not only CCT matters, the 4000K cannot be named “safe” or “safer” sorry SKV89 ;).
I would think it’s a combination of factors that link this all together. IMO it’s mostly to do with ones lifestyle. If you’re up late regularly chances are you could be in the presence of bright light which further interrupts the sleep cycle.
Night shift work may seem like an odd thing to link to breast cancer. Nevertheless, scientists found that women who work night shifts for many years are more likely to get breast cancer than other women. This includes nurses and flight attendants who...
Est. reading time: 6 minutes
At the bottom of the first paragraph “Researchers found that night shift work links to breast cancer because it can change a person’s sleep-wake cycle. This has a lot to do with artificial light.”
wle
AsI recall, it takes only a brief exposure — think incandescent white nightlight bulb — to suppress melatonin production. Then it takes half an hour to an hour for the body to resume produccing melatonin. It’s the melatonin that suppresses breast cancer (which is why night shift workers and people in areas newly supplied with nighttime electricity show an increase)
https://www.google.com/search?client=firefox-b-1-d&channel=tus&q=melatonin+night+shift+cancer
Light at night is bad for your health, and exposure to blue light emitted by electronics and energy-efficient lightbulbs may be especially so. ...
You can buy a spectrometer kit (several variations, varying prices) from PublicLab.
https://store.publiclab.org/collections/bulk/products/lego-spectrometer-kit?variant=8187504787563
EDIT
Here’s the spectrum from one of the claimed low-blue-light 110v bulbs
See blue light associated with prostate and breast cancer - #23 by BurningPlayd0h from DominikM for spectra
I used my kit spectrometer to check the claims of bluelight suppression. A lot of it is hype — f.lux for example changes the apparent color temperature by adding more red, rather than removing blue. The spectrometer shows plenty of blue light still being emitted from the computer screen (whether fluorescent or LED lit).
I swapped amber LEDs into half our home flashlights, for nighttime use, and for room lighting we use amber LED bulbs or “bug light” compact fluorescents for evening light during the short-day half of the year.
Doing that cured our insomnia, which had gotten bad when we replaced all our incandescents with “white” compact fluorescents some years ago.
I think CCT is actually still a huge part of what’s happening there. Even 2700K light from a blackbody source will have far less of the blue end of the spectrum compared to 4000K.
