Do you think this is the same optic Wuben and FireFlies used in their quads? If so I would liken it to something between narrow and medium beam width and lightly frosted in “Carclo” terms. It’s pretty good if you are not looking for overly throwy or overly floody.
Edit (stolen from Wuben thread, thanks Chatika vas Paus):
Yeah the Wuben/Fireflies quad optic is much wider than a Carclo triple.
The KD triple optics I have are very throwy, and have almost a clear, “empty” looking spot right in the center of each individual optic. You can clearly see the emitter with no distortion/magnification I can see through the center. They don’t seem as efficient Carclo ones though, but that could be the light going into the wider spill vs Carclo narrow spot maybe? Hard to tell by the naked eye.
So, I have some plans I want to try - I finally got myself to order a programming device. Background is, that I want to use the light mostly in momentary mode on turbo but be able to use regular modes if I need them.
Does anyone know if there is an unused input pin on the chip for a second switch?
Are there schematics online somewhere?
Are there just the PCBs available to buy for cheap maybe (cheap as in I don’t have to buy a whole FW3A if I fry a board)?
Anyway, here we go:
Plan A:
Alter firmware to make flashlight always be in momentary turbo mode, defining a sequence to leave it and go either into a slimmed down Anduril or some own modes. Turning the light off will make it be in momentary mode again.
This should be doable without any hardware modifications except desoldering and resoldering to get to the microcontroller - I think I can do that if I invest enough time to alter the firmware
Plan B1:
Alter hardware to add a secondary switch on the side. This secondary switch will be connected to the the pin the tail switch is now connected to, Tail switch will just go to turbo, bypassing the microcontroller
I don’t know yet if it’s possible to simply bypass the microcontroller for turbo
If it’s possible, the light won’t have any LVP in momentary mode anymore.
There is only momentary the tailswitch can do, nothing else and there is no easy way to change this.
Plan B2:
Alter hardware AND firmware to add a secondary switch on the side. This secondary switch will be connected either to a free pin of the controller or maybe via voltage divider trickery to the same pin as the tail switch
All functions should be doable via firmware
LVP should stay intact
This will require a load of work
I think I have the skills to rewrite code to make it work, but I lack mechanical abilities/tools/knowledge to fit a side switch into this thing. I could design and 3D print an outside part in ABS that can fit a switch and drill a hole for the cables (and order a metal 3D print if that works and i’m happy with it). I thought about replacing the whole middle part with the shelf with a metal 3D printed part but I don’t think this will work out because of the threads - metal 3D printing is not that exact.
But again, only if I find enough time and motivation to do so.
