i need a reliable charger for eneloop Pro batteries, some 16430 and 18650’s. The charger is for my dad so it should be quite simple to use. Most of the time he will be charging is eneloop cells.
I’ve had two Fomolov A2 chargers which charged Li-ions just finde but did overcharge all the eneloop cells, resulting in a top voltage of over 1.70V - dont ask me why… (charge current was 1A).
Preferably a 4 channel charger - a 2 channel charger would be ok as well.
Limit: ~25€
It would be great if the charger is available at nkon.nl.
I just bought a liitokala li500 on sale, I think it was around $25.
It just came in. It’s easier than my opus was to use ( not that opus was at all difficult.)
The new Li 500 is a great charger so far, it’s very simple
One thing to note — both the Lii-500 Engineer and the new Lii-500S have a USB-out port, but have different functions.
On the Lii-500 Engineer, the USB-out port is a powerbank function (when power is disconnected, and there are li-ion batteries in the charger, it will be converted to “power-bank”.
On the Lii-500S, the USB-out port is a USB charger — it will only work when power is connected, and does not work as a powerbank.
Well I checked out the LiitoKala 500 and according to a few reviews it seems to overcharge batteries over time if left in the charger. That’s not the sort of simple and safe charger I would want to give to my father.
So I ended up ordering a Xtar VP4 Dragon Plus from nkon for own purposes. It will replace my Golisi S4 I been using as main charger. And that one will go into my fathers hands.
Oh, that’s no big deal for my use. If anything I’ll leave them in while I am busy, the most they would ever stay is 8 hours or so. Normally they are off within hour of full charge
Thanks for that info d_t_a, I did not know that.
I could care less if it is a ‘power bank’, I would never use that. But…. I might actually use it as a USB charger at times.
