It was not my choice.
The company who did the shipping in Germany was somewhat unable to deliver to my original address.
They could not handle a company line.
I did not choose the type of shipping, it was the default for Germany.
All shipments where sent domestically and not international.
I didn’t do anything special. Opened it up, tossed a GA inside, and play with it every now and again. It did see some pocket time on Sunday, but only a couple hours. Other than that it’s been sitting on my desk bezel down when I’m not using it.
I have seen a number of Cree datasheets over time, in which all emitters at 3000K were 80 CRI minimum, and wrongfully concluded that it was true for all Cree emitters, sorry about that. At least it is true for the XP-L Hi, which is used in the FW3A.
Has anyone else put the UCL lens on an SST-20? Do you have before and after shots? Still waiting on mine, so I am stuck living vicariously through those of you who have received theirs.
For those with the FW3A and it’s “heavy” switch action, and awaiting or has the FW3C with its “light” switch action, consider swapping the switches. I found that the heavy switch goes well with the heavy light, and vice versa… There’s just something it does to my mind. When I pick up the heavy light, I appreciate the heavy switch action,and also vice versa.
I didnt do anything scientific but I was pretty sure when I pulled both switches they were identical and the difference was actually how the tail opening was milled and the sizing of the nub was slightly trimmed. So if you moved the rubber gasket and nub that would make sense but if you only moved the metal tail it doesn’t make sense to me.
Mine just randomly showed up today! DHL and USPS never showed any tracking. A few observations.
The UCL lens does nice but minor changes to the tint.
The SST-20 is very neutral considering it’s CRI is great!
My nubbin stays in the boot and is not apt to jumping out.
My rear spring is soldered nicely, there is plenty of clearance over the trace, all three pads are soldered flat, and the sharp of the spring is on a pad.
The switch was nice and clean, I just replaced the kapton tape with mine which is wide enough to cover the entire metal switch.
I did need to slightly move the driver. When tightening the head tight it would switch on it’s own, when just snug it was fine though.
There was some solder running around freely under the optic. I used a nylon spudger and carefully removed both pieces. Everything else looked fairly clean, but I will clean once I have cotton swabs.
The switch feels really nice, but is a bit sensitive. I will be trying some stuff mentioned to tune it.
