Very unlucky with my PL47s.
Here’s a short story, tried to write it totally neutral.
My first PL47 with SST-20 4000K paid on Dec2018: 3 out of 4 led’s were working. Glad that I have received replacement head after 1,5month. Summing up the awaiting time I could start using after 3 months since purchase.
The replaced head worked fine. For a week. When I activated turbo I saw after a minute clear light power drop. I thought temperature management worked. But not. One of LEDs stopped working.
Again I was left with 3 out of 4 LEDs working. I wrote to Neal. And until today: zero reposponse.
The funny thing is meanwhile I had won a GAW from tatasal, so I also have a third piece of PL47 with XP-L HI 6500K. But I’m kinda fed up with this light, so it lies deep in my drawer (PM me if you’re interested).
I’m wondering what’s wrong with these lights. Is it messed temperature management or these SST-20 have some deffect? That’s a real pity because I find the light very interesting and useful. Well… waiting for another 21700 fancy headlight, hopefully with better QA management.
The awful switch boot was the failure point on mine. It started ripping apart from light use so I smashed the lens and salvaged the 219Bs at least. I got luckier with mine than many people here on BLF though, even having been in the first batch.
Bought 2 directly from Jack at ff. Both are 219B. Rarely use turbo and even then a few seconds at most. It is my “go to” headlamp with a JetBeam headband. Have used it almost every day since it came out. Just drains 21700’s faster than I first expected. Also I use copper washer in tail. Don’t have to tighten down hard anymore. Batteries were Samsung 50E but switched to LG M50 INR 21700 5000mAh/7.3A Flat Tops. Only problem is I can not charge them in my Xtar Dragon VP4 Plus due to recessed + terminal. Charge fine in Xtar VP1…go figure!
May I ask for a picture of the copper washer you used? My 2pcs Lii-40A 21700 are already dented due to being used in the PL47 (I rotate using the 2pcs Lii-40A)…
I got the 2 mm version of this size. That product is out of stock. If I ordered again, would probably get this one (1.5 mm) since part of the tail o-ring is exposed. Others earlier commented that a 1 mm thick would work, but I never tried those.
I’m up for a Gen II. Sounds like some nice improvements. Me and my apprentice use ours daily (plumbing hvac) and I was hoping I could obtain another 219b in the future. Looks like it will happen.
Had a screw up tonight. Dropped my light while taking it off my head and it landed bezel down on the linoleum floor in my mud room. I picked it up to this,
Anyone ever replace the glass on their PL47 before? Recommendations?
I can’t help you source a new lens but hopefully someone else here knows the dimensions and a source for replacements, also don’t know how easy/reliable reinstalling the press fit bezel ring will be.
However, I did open my Gen 1 up for the 219Bs when the swtich died, so:
1 - Carefully shatter the lens (You’re already a step ahead of me!!! )
2 - Use a small pliers, tweezers, etc. to pull out any pieces you can. Something small to pry/lever them out may work too, but this could scratch the optic underneath if you care about that.
3 - Wedge a small screwdriver or knife under the bezel ring where the lens was and lever it upwards slowly, working around the circumference of the ring. Don’t try to pop it all the way up in any single spot all at once, just a little at a time prevents it from being wedged into place on the opposite side.
