Hi Ban,
I want to order 20mm quad XP-L HI warm white.
There are two XP-L HI emitters listed:
3000K T5 7C1
3000K - 3500K U4 7A2
I want the U4 7A2 emitters on the quad mcpcb. How can I be ensured that I get those emitters? I do NOT want the 90CRI TT5 7C1 emitters. I cannot choose on the quad mcpcb selection.
Thanks
Diomedes
(Diomedes)
July 18, 2019, 9:49am
1484
The scrolling banner on the main page of KD says the “new style” KDLITKER C8.2 with XHP50.2 is $23.99 but when I click on the banner and get redirected to the product page, it’s $27.99. The price should obviously be fixed to be consistent, but also I’m curious about what’s been updated on the C8.2 to make it “new style”? I already really like my C8.2 with XHP50.2 and wouldn’t mind buying another one if it’s been updated (hopefully with an integrated shelf instead of pill).
adam7027
(adam7027)
July 19, 2019, 2:14pm
1488
1stein:
White flat is on KD….
Feed your hunger here
Hello Ban,
Is that CCT value of 5400K correct for this emitter, or is not? (I wish for it to be)
contactcr
(contactcr)
July 19, 2019, 2:35pm
1489
Even if it is right it wont be anywhere close to that at max power
What size are these Osram LEDs are they the 1/ 2mm?
Scallywag
(Scallywag)
July 19, 2019, 4:01pm
1492
Hmm, if accurate, 5400K is much warmer than I've seen them elsewhere.
HONDARIDER
(HONDARIDER)
July 19, 2019, 4:12pm
1493
I would grab a couple if they were actually neutral. That would be awesome.
Barkuti
(Barkuti)
July 19, 2019, 4:33pm
1494
I calculated the CCT for an fcbB46 at an (0.330,0.348) average rhombus point following this equation :
CCT= (-449n³) + (3525n²) - 6823n + 5520.33
where n = (x–xe)/(y–ye) is the inverse slope line and (xe = 0.332, ye = 0.186) is the epicenter. x and y are the coordinates.
The result is ≈5600K (≈5605.1K). So its still daylight “cool”.
Cheers
Sweet these ones can be used with direct drive to easy. Thanks
1stein
(1stein)
July 22, 2019, 5:25am
1496
Can’t access KD right now, does anybody experience simmilar problem?
The page loading time goes infinitive…
cayman
(cayman)
July 22, 2019, 5:31am
1497
same here. started during the weekend though. Around Saturday afternoon?
Same here… My shopping cart is idling for now.
Yea same its not loading for me. On the weekend it was fine.
1stein
(1stein)
July 22, 2019, 5:38am
1500
Right, my cart is being serviced right now. Oftenly overloaded needed some re-welding
BanL
(BanL)
July 22, 2019, 2:36pm
1501
Sorry friends
I am seeing what is problem with the server right now.
It seems the network connection has some problem.
Sorry for any inconvenience cause to you.
1stein
(1stein)
July 22, 2019, 2:55pm
1502
BanL:
Sorry friends
No problem, but hope you will manage to fix it. Good luck Mr Ban.
