I’n in your region Muto, gonna be 100° F or more(like it matters after 100 )here tomorrow
Netatmo Weathermap
Real-time weather data from the world’s largest community of Smart Home Weather Station.
91, but according to weather app “Feels like” 103
Working outside really sucks sometimes. But mostly I love it.
Raccoon.
Your calender dates for thurs through to Sun.
Are our current daily temp’s In Celcius.
Mid winter.
We’ve never had temp’s that cold in the 47yrs I’ve been here
Mornings…*7c to 24/26c. Normally 12 to 14ish O.Night.
This “Climate changing” is certainly changing things round the world.
Weeklund.
Australia.
We limited to 5kw (household) if on grid. Unlimited if not.
I have 4.2kw.
Runs. 2 storey home plus pool pumps, Covers ALL running/service costs.
Gives us 44c per kw turned into grid after usage. (till 2028.)
Av around $650ish Per yr cash return now. Was over a grand at beginning.
(Service costs rises.)
Initial costs . Out of our pocket.
$16.4k AUD. We were worth MORE than your Dollar then.
Around $1.6 or $1.8c US to AUD.
Now. Around 65C US to $1 AUD.
Somebody likes your president.
Preferably. Have MORE panels than Inverter capacity.
Keeps system MORE efficient
during it’s cycle.
IE max inv input for longer, while sun shining. Wasting a little panel output
at times but higher returns through grid.
We Use Heater and Aircond as WANTED… not can afford.
Leave it on ALL the req’d seasons. 7/8weeks Winter temp’s.
three months plus of hot temp’s.
Paid for itself in under 7 yrs.
Oh. Evac Tubes (30) HWS there too.
Near Constant hot water when sun shines or air hot during night.
We right on the Tropic of Capricorn. (23km North of)
Most stable, constant, climatic band on the planet.
Check it.
Here in the Sunshine State we have two seasons :
Nearly unbearably hot and humid and then nearly perfect .
It's also known as an evaporative cooler.
They only work when the dewpoint is below about 55 degrees, so like chinooker says, it won't work for you.
They're great when the humidity is low.
Tip of the day: Hold ALT key and on numeric keypad type 248, gets you the degree symbol °
My numeric keypad is full of macros.
Hot and humid here.
another near perfect day in Santa Barbara. high was somewhere in the 70s, a bit of damp fog in the morning, but beautiful in the afternoon. Supposed to be 5F cooler tomorrow.
Probably only 200 miles straight line from racoon city, but a world of difference. He’s only about 75 miles from the Pacific Ocean, but about 40F away in daytime high temperature.
My readings are on the weathermap, Northern part of The Netherlands
If I could afford it, I would love to move to the California coast!
Santa Barbara is one city of many that interests me.
35c (95f), in the shade, now
As usual, warm.
104º F, real feel 110º F, (40º C, feels like 43º C),
Mostly cloudy, cloud cover 88%,
Humidity 32%, dew point 70º F
Wind: WNW at 4mph
No weather to play with a new Sofirn SP70!
Yes, the cost of living here is quite a lot higher for sure.
What is a swamp cooler?
When his swamp gets a bit too hot, it cools it down?
Tips and tricks to make living in the heat/sun better:
1. Wear white clothes.
2. Wear a cap.
3. Bring your own water bottle.
4. Drink lots of water.
5. Wear sunscreen.
6. Get yourself a portable fan.
To make inside living better:
Man, it’s hot.
It’s like Africa hot.
Tarzan couldn’t take this kind of hot.
And no, it’s not a dry heat. It’s like breathing-through-a-hot-wet-towel heat.
Highs here have been running in the mid 90’s, Lows in the mid 70’s. Humidity ranging from around 80% up to 99%.
But…. Highs for the next few days are gonna be in the low 80’s & Lows in low 70’s & high 60’s. … That suits me just fine!!
One trick I like to use when it does get hot, is to put a wet bandana around the back of my neck and draped over the top of my chest. Evaporation cooling is pretty helpful. If its super humid where you are, maybe this doesn’t work?
It’s 19*C here.
It’s gonna be 24*C tomorrow .
