Olight S1 Baton Dimensions Question.
Does anyone know if all the Olight S1 Baton (500-600 and 1000 lumens) are of the same length and diameter? Asking because I have the 500 but want to purchase a higher lumens output and not sure if it will fit in the same leather holster.
Thanks guys! :+1:
If you mean S1 Baton vs S1R II Baton. I believe the diameter is the same, but the S1R II is maybe a couple MM taller. I can get pics and measure later.
S1 comparison
As you can see it’s only slightly taller. 61mm vs 63mm. Width is about 21mm vs 22mm, not counting the clip.
Edit: Sorry for the poor image embed. I can’t find the proper link on Imgur anymore. I think they may have removed it.
