I’m hoping a video will be made on the D4 going nuclear just to see what would happen when left unattended, it will obviously set fire to any combustibles close by , but will the actuall light melt & catch fire or will it act as a pipe bomb?
This has already happened to 2 people. The head of the light suffered damage such as melted optic, damaged wiring, button popping out. No other significant damage occurred. The lights did not explode and no nearby combustibles caught fire.
That said, I suppose combustibles could catch fire if something flammable happened to be in front of the head of the light.
So. It does not work. And my D4V2 which is not mine. Bought for a friend now always starting in ramp max. No mode memory left. I flashed many lights but this is something went wrong. The flashing does not run down once. The pop up window closed immediately and now I have a flashlight not working as it shoud and someone paid me for it to order to him. And I am here with this mess. Sorry guys cancel my offer. I don’t want to ruin anybody flashlight and now what should I do?
I don’t know how TK and Hank want from unexperienced people in flashing to do this at first time.
I don’t think that’s the issue. The bug could have happened with a different portion of the UI besides muggle mode and we’d have the same problem we have now.
Muggle Mode by itself is fine. The only problem is the bug.
You have reflashed many lights, but had no success here? I have no experience in mods,flashing, or soldering, yet I am told that with the proper equipment, it should be easy. I saw in your previous post that you put together your setup. I’ll bet that when Hank’s setup becomes available, you can successfully reflash this light. It’s too bad your friend may need to wait for his light.
Absolutely no shorts. Ichecked before first use multiple times. rechecked now. All wire connection goes to pins so no contact problem either. The light aux led turn red blinking when connect the pins.
This is what I used:
avrdude -c usbasp -p t1634 -u -Uflash:w:andurild4v2.hex
TK wrote this to use.
I flashed more than 200 lights.
My “friend ” messaging me every day multiple times when he can pick up his light and he wanted to came wednesday. Now I can’t tell him to wait or I can’t pay him back and we are here with a worse light than it arrived. He is not a patient guy. So I am sure if I need to wait a month again he wil messaging me every day…. That is why I usually don’t buy lights for other people. If something goes wrong I need to do warranty things or repair lights or loose money. The pin connector is OK I don’t think another one do the job. Maybe some fuse settings missing from the line. Usually flashing scripts have fuses. I don’t know why this not have.
You said it starts at Max ramp, can you ramp down? TK stated that as long as the fuse values are not changed then there is little risk to brick. Have you tried reflashing? Maybe it is set to manual memory and it was on Max ramp, did you try 5h to switch to automatic memory?
yes I can ramp down and seems other things work just it always start ramp max with short click. long click it starts moon then ramp up.
The flashing sequence not even completed once. I tried it many times and not doing the flashing sequence.
:+1: :+1: :+1: OMG that’s the best reasoning I’ve seen. I remember back in the 90s when running the x86 and Pentiums that cost over $2k+, I spent more time trying to figure out DOS and Windows 3.1 crashes, bugs, hardware drivers not working, etc., than actually using my computer. Windows Xp was the first windows stable enough to use without constant fear of crashing and losing work, but it still had its fair share of problems. Apple IOS is probably the most bug free OS I’ve ever seen but it is developed by thousands of engineers and hundreds of billions of dollars, whereas Anduril is developed by a single non profit hobbyist and Emisar is likely not even a registered business operated by a single flashlight enthusiast from his home.
