Lumintop does all the blueprints.
That would do it. The star on the FW3A isn’t screwed down. If you ran it for more than a few seconds on turbo without the bezel on, the star could very easily overheat.
Yes he did but it was burning & or smoking before the bezel was taken off , I could smell burning so I took the bezel ,optic ,lens off to see where it was coming from.
Your on a roll mate…. keep it up!! :beer:
I’m guessing one of the Leds was not flowed on well and it wasn’t transferring the heat like it should. It’s important that the center pad under the led, the thermal pad, is soldered properly. This made the one led turn blue and start burning/smelling. Then removing the bezel and going Turbo really fried things. So a pretty rare chain of events and not something that happens often. Normally the XPL are tough and can handle more current than the FW3A can produce.
For those interested, Mad Max just did a video where he installs the glow gasket as well as the new glow switch.
Good video. How long do the gasket and button glow after the light is shut off?
Guys, is there any optics replacement for FW3A available? I need striped lens that make the beam oval (for cycling purposes).
Carlco 10510 elliptical should be perfect for you.
:person_facepalming: of course, it’s standard 20mm optics
cabfrank - many thanks :beer:
whats the lumen output max on the sst20 version ? it doesnt say on neals page.
someone earlier in this thread tested the 4000K high-CRI SST-20 version at 1800 lumens max.
1stein. :wink: I have one too for my bike, but haven’t tried it yet. I think it will work well.
After 6 to 7 hours, my "aqua blue" gasket still has a faint glow. Enough to see (and locate the light on the nightstand) in a dark room.
how is this possible? my green fades away after just a few min, hours? thats not possible… im kinda dissapointed in glow gaskets compared to aux leds they only shine for so short time so i dont see how it can shine four hours…
My CRX aqua gasket glows for hours and hours; I can still see it in the dark about 6-7 hours after too. It is a lot dimmer, but it’s still visible with fully night adjusted eyes.
Not joking. For instance, last night — I had used it a few minutes on one of the lower modes at about 9:30. The gasket was glowing nicely from that. I went to bed at 10. Alarm on the watch woke me at 4am and I could easily locate it on my nightstand to get up with and start the day.
I think the problem is people photograph these when they are just activated and the “dim” glow hours later is only visible with night adjusted eyes, at best, so it’s a bit misleading. Unless maybe someone is sneaking into your houses and shining UV light everywhere while you sleep… o_O
okay my copper version arrived today. First impressions its heavy (duh) and feels well made. Switch compared to my group buy light feels easier to press and is alot quiet, not that it matters really i found the switch on my normal fw3a pretty good. But its nice to have now also a copper version, i really like the extra weigth too it. Really a gorgeous looking light here some quick pics…
Mortuus, What tint option did you choose for the aluminum & copper flashlight?
