Opened a stock Niteye Eye10, removed stock reflector, installed replacementā¦
Original reflector gave 550 lumens, replacement gives 625 lumens, same battery.
the kaidomain 21514 reflector has a tighter hotspot, smaller opening at the bottom, than stock.
I like this kaidomain 23424 reflector better, the hotspot is a bit larger but without the ādonut holeā in the middle of the hotspot)
the replacement reflectors are slightly taller, the bezel does not screw down quite as far. Although still far enough to cover the O ring on the body
thanks to moderator007 for researching and finding these kaidomain reflectorsā¦ much better beam, without the rings from the stock reflector (especially w N219b)
they are made for slightly larger diameter lights, hence the bits of leather I addedā¦
super convenient tool, that was my first test to see if they would be strong enough to break open a stock factory glued bezelā¦ so farā¦ winner! Its a size specific tool, dedicated to my RRT-01 accumulation
does not hurt as much when I drop on toesā¦ plus these are not as easy to pop on and off, but they have a more āuniversalā fit:-)
Yepā¦Vapcell 18350ās kick booty and itās very dependableā¦.never misfires, taken it apart hundreds of times, the retained style tail cap of the NovaTac is what the FW3A tail cap should have beenā¦
First of the yearā¦
Bought this cheepie headlight from one of BigClive teardown vids on YT.
Pretty neat has the hand wave on off option. Other button is Hi, Lo & strobe.
Neat light for what it is and the 1200mAh lipo made it worth the $8.
Cut down a Noctigon XP 20mm, flowed a L1V2 4000K on it and put some real wires on the battery.
Nice light weight light and it will get used.
Yeah guess you need a beamshot too. Not a fan of a headlamp with a hot spotā¦ might sand the clear lens to help diffuse the spot. But I just got it todayā¦
