So to change the aux LED mode: 1 click to turn on the main LEDs, 4C or 4H to change the aux LED mode, then 1 click to turn the light off to see the changes?
It’s a meme.
It’s used as a general unit of measurement for how advanced a computing device is. The original DOOM game has been ported to all sorts of things… such as a graphing calculator, a refrigerator, a camera, a toaster, etc. Similarly, when flashing firmware on an AVR chip, the process runs at roughly the same speed as an old phone modem. It’s basically just a reference point to give people a rough idea where things are on a massive spectrum.
Whatever is done, something needs to be put in place so that a flashlight never turns on by itself. That is the absolute worst thing a lithium-ion light can do. And since thermal protection was also turned off, that just made the situation worse. If thermal controls break when you’re using the light, it’s an annoyance or perhaps a minor safety issue. If the light turns on when you’re not around, there’s nothing you can do.
So, whether the code is structured in such a way that when the light is put into the “off” state, it’s impossible to come back on unless the switch is clicked. Or, exhaustive testing is done for every different “off” state there is to make sure it doesn’t come on. IMO, exhaustive testing is unlikely, especially for small projects. Or, perhaps just make an optional stripped-down “safe” firmware available when you order it (though toykeeper said that might not work in reality).
I know people will say, “Just take out the damn battery or mechanically lock-out the light” Sure, that’s an option, but you can be certain that most users are not going to do it. So you’re basically saving 1% of users and ignoring the other 99%.
That’s a niche within a niche market. Everybody in the world that wants to update their flashlight firmware has probably already posted in this thread. And you can probably count their numbers with your fingers and toes. Once you make a flashlight as complex as a smartphone, you may as well just use your smartphone.
All that said, I’m really torn. Yes, I like fancy firmware that makes a flashlight do lots of cool stuff. It’s fun. But, I think it turns a flashlight into nothing more than a toy. If you can’t depend on a light, it’s not really a tool anymore. It’s a toy, so put it away without batteries when you’re done playing. I guess there’s nothing wrong with that, as long as the buyer knows that. They’re not marketed as toys, though.
I really want a toy and a useful tool. But I think this situation has taught us we can’t have both in one light. At best, you get something that leans one way or the other.
So long as we are making demands upon our volunteer firmware developer(s), some means of using a config file would be fantastic. If only there were a decent way to get it into the device.
In reality, I’m well aware of the difficulties with such an unreasonable request, and as a volunteer at a large volunteer-run makerspace can appreciate the problems associated with voluntelling.
Before I go wiring everything up (I have all the hardware now), I want to confirm the silk-screen labeling on the driver board. "MI" would be third pad from the left and "MO" would be the far right pad ? ? Or the other way around? I don't want to assume . . .
That is the assumption I would make. Seems to follow the labeling.
From what I also understand, as long as you are not flashing the fuses, you can repeat if it’s not wired/via’d correctly without harm.
ToyKeeper has said something similar:
The command does not have any fuse values in it because of two reasons:
The fuse values should not need to be changed. Attempting to flash new fuse values is risky because it can make the MCU unflashable. So that part is left out on purpose. As long as the user does not try to change the fuse values, it should be safe to reflash as many times as necessary.
Yeah, I hear you, WalkIntoTheLight. I’m torn, too, between the poles of robustness on the one hand and innovation on the other. I suppose I want Anduril to “lean” toward innovation, in part because there are emergent features (e.g., adjustable color temperature) that I want. And in part because there are already so many options on the robust tool end of the scale. There are Malkoff or Elzetta (with potted electronics, mechanical switches, etc.). And, if those are out of reach, there are Zebralight or Olight or Acebeam. I do think of my Emisar lights as tools, but as exotic ones. In 2005, my first LiIon powered light, the CPF Peak Rainier, was universally regarded as a toy (and a dangerous toy, with no thermal or timed step down). Now-a-days, reliable LiIon powered lights are mainstream tools. My first programmable Ra was a far cry from a current HDS, let alone a D4V2. I just want to encourage innovation to continue, but I totally get the concern over side effects.
I think I'm 95% there. After spending all afternoon building a fixture and installing software onto my Lenovo desktop, I'm finally able to "initialize" the D4V2 driver board - which I think means almost everything is working. The commands I'm using are underlined in blue, are they correct? It's my understanding we can ignore the sck error.
But, as you see, there's a signature error which keeps me from actually flashing.
I hope there will be a thread just for the instructions and help with flashing of the D4V2. There's no way I'll want to try and sift through this thread for examples and tips after I get my kit from Hank, especially having no clue ATM, on the flashing process.
If there is going to be a specific D4V2 flashing thread, please link to it from this thread. I'm going to need all the tips and detailed instructions I can get, all in one place.
Well this is where I'm stumped, I can't find a version that has t1634 support.
I'm was using version 6.3 from here (which says it's from 2016). Still same error message. Another site said the latest version was here, but that's the one from 2010.
ToyKeeper, do you (or anyone else) have a link to a version of avrdude that's guaranteed to have 1634 support?
There will be definately a specifit D4V2 reflasing thread, including how to use the software and hardware, as soon as the software is installed into your PC, the reflasing process is simple, the whole reflasing process takes about 20 seconds. I hope there will be video to demostrate how to reflash the firmware as well.
As for the price of the reflashing kits, it’s $8.5 including registered shipping for D4V2 owners, while the regular price is $18.5.
