Agro, did you finally pick any of glowing ropes?
Don’t forget to make some pics. I would gladly take advantage of your findings as I’m planing a scouting bivouac with my toddlers…
Thanks MascaratumB.
I’m leaving for Pol’and’Rock the day after tomorrow so it’s unlikely to arrive by then. Just like the relfective rope that is on the way. So…for this year I can only try glow tape strips. For the next one - I have a lot of time to collect and test various ideas.
GITD tape isn’t super expensive. Why not apply a few pieces taped over each of the guy lines. Like about 4 or 5 “tags”? Or if you camp frequently, maybe get some cheap GITD markers and use a little duct tape to secure them in place spread across each guy line?
I use the MLH micro tensioners. I’ve used Atwood cord and it is a great product, but the only experience I have with the GITD version is seeing it use by others once or twice and it seems to hold a glow reasonably well.
I have no idea about availability in Poland however.
Thanks, you seem to be the first person recommending a glow rope while having some experience with one.
The cost is quite high so it will be at the end of my list of the things to try - but I will put it there.
One caveat, I’ve only seen the GITD relatively early in the evening. If your main concern is drunks stumbling around at 2 AM, I have no idea how well it is still glowing at that point.
Honestly I’d probably just hang a red fauxton from the middle of the guyline.
I really think you should consider the EL wire that ImA4Wheelr suggested. I don’t know how long the batteries last but you will not miss it in the dark. This model has slow and fast blinky modes.
Anyway, I’m back from the festival.
I tried the glow tape, it didn’t work at all. There was too much light around killing night vision.
When I used a flashlight to charge them - they were visible. But not enough to catch attention of a sober person, let alone a drunk one.
Without chariging they were barely visible when I knew where too look. Useless in that setting.
So…a glow rope would probably work even worse.
I guess it takes some electricity to be visible in such setting.
It’s hard to know, because the brainwaves are totally cut off from the aluminum foil. Well, I guess that answers my question.
Yeah, in your scenario it sounds like you need some low intensity flashing LED modules. You can buy them fairly cheaply from China these days. It’s just that deployment and recovery is tedious, depending upon how many guy lines you’re addressing. But at the same time, it may be too distracting, like some kind of carnival setup (little red flashing lights all over).
How about this? Motion sensor! Set up an LED light to shine onto the area, rigged up with a motion sensor to turn on at just the right time, before an inebriated fellow reaches the stumble point.
Was just thinking… someone could just fidget something together out of a set of LED Christmas lights. Split the 3-wires into a strand of 2 (they “switch tracks” in the middle), and while they’ll all be in series, a cheap circuit that just dumps a quick HV pulse through ’em every few seconds would be enough, and the battery would last a loooooooong time.
