The SW40K will have better red color rendition.
Wonder what current this was taken at
These were tested at 200mA.
So according to the test results would the sw40k be the better overall performer maybe just a little dimmer?
I wonder why the test result does not show the DUV value. The SW45K seems super rosy according to the graph and the SW40 seems rosy too. Considering it is tested at only 0.2A, at 1A or above, the SW40 should be the better looking tint since the SW45K might be too rosy.
I seriously appreciate the testing, thanks for doing it.
But I too am wondering if 0.2A data is relevant to the power levels we want to run through them.
On paper, yes I would agree that the sw40 should be better in this case.
200mA is on the lower end so we can expect the CRI to drop a bit when more current is used. Still these emitters should prove themselves to be very nice. I plan on swapping some of them into my lights this weekend to see how they perform. Will post beam/tint shots when available. Stay tuned!
And DUV drops as current increases meaning it gets rosier
Updated the OP with DUV data. Thanks for reminding me.
sw40 DUV: –0.0031
sw45k DUV: –0.0044
This will certainly appease the ever growing pink crowd. Not my preference but i’m the minority. If the lower CCT ones end up closer to BBL i’d get a few
Really looking forward to my emitters now…
Sorry for all my questions but what does this show/mean?
Shows tint. If it’s positive it’s above Black Body Locus (green). If it’s negative it’s pink.
Here’s a random website’s graphic, the line in the middle is “0.0 Duv”
But the lower your CCT is the more the “green side” looks yellow. Same when you go to the extreme other end. More blue mixed shades
Jon, I actually didn’t know there is a N219b 4500k 9080 SW45 and a N219b 4500k 9080 SW45K. What is the difference? What does the “K” stand for? I couldn’t find any info in the spec sheet.
the k means nice and rosy! its my favorite
the no k is still a little bit rosy
here is the rundown in pictures… (one page back)
I do not consider the N219c 3000k 9050 to be “rosy” I do not consider the N219b 3500k 9080 to be “rosy” I do not consider the N219b 4000k 9050 to be “rosy” I Do consider the N219b 4000k 9080 to be slightly “rosy” I Do consider the N219b 4500k 9080 to be slightly “rosy” I Do consider the N219b 4500k 9080 sw45k to be Very “rosy” [image] [image] [image] Rosy is relative to ambient white balance [image] my sw45k EDC, during daylight: [image] my personal preferences I really like the ex…
and more info
[QUOTE=staticx57;5306253]Maybe it would be worth deep diving into Color Temp and Tint.
On average we expect an SW45k to be more rosy than an SW45 [/QUOTE]
So it looks like the the sw45k has a lower r9 value than the sw40k. What does that mean and which led has the better results?
I think that is an error
I believe this is more accurate
both the sw40 and sw45k have great red rendering, the 45 CCT is cooler white, and its tint is pinker
Can someone tell me how to differentiate the cathode and anode sections? I also having trouble finding a data sheet anyone have a link. Thanks so much.
I usually place the LED with the cathode mark (triangle) on the upper right like so: [+] [-]
But following diagram shows the cathode on the left side, hence the triangle on the bottom left. Hope this helps.
Not the most scientific but here’s a general comparison of what the sw40 from this bin looks like:
The 219c 4000k looks rosier than the sw40 and sw45 in that comparison. That sw45 is not a sw45k correct?
Also is that 219c 4000k the stock emitters that comes with the FW3A? Surprised how nice it looks considering all the the 4000K 219c I’ve seen in the past are greenish.
