interested but please what are the specs? which gaskets will fit?
No glue?
I’m IN
Hi Martin,
Please ask Lumintop to make a screw in bezel that can at least be loosened by using a circlip plier. This would retain the looks as well as please the modders out there.
Oh, and what bin will the SST-20 emitters be? Same as FW3A??
I take it the light will unscrew from the head for battery swaps and access to the driver?
$35 puts it directly in line with the D4v1, which has one more emitter and can be had with shorty tubes. I was expecting / hoping it would be a bit cheaper tbh.
I am not sure about the shape of the switch boot. It sticks up a lot and is totally flat. Looks a bit funny. I hope it’s just a photoshop.
No glue and possible 18350 tube. I’m in!
Interested.
Hopefully SST-20 4000K tint is ok.
Any dimensions? I’m interested but would like it to be smaller than a d4 v2.
Interested
Hi Martin,
I’m glad to hear about the bezel!
I see it will be a 4000K SST-20, but there’s no indication of the tint bin? The FW3A/C SST-20 bin is FD2. Can you confirm this please? Otherwise I’ll probably take the Nicia 219C model.
I miss the USB charge
USB charging will make the light bigger than what Lumintop is aiming for.
Martin, would you please add one to my request, to make a total
of two (2).
“Launch date, Sept, 2015”?
Martin,
Can you please find out if the switch is separate from the driver (like the Emisar D4), or is it on the driver (like the Astrolux S43)?
fixed - thanks! :beer:
Interested
Interested
Great update MadMax. Bezel is removable
