I must confess I do not have any idea if this strange look comes from a typo by Jacky or if it is really meant to be "B duilding". I took the address "as is" from Jacky's original first draft of the manual. As we had to get everything sorted so quickly, especially about the specs, there was no time to have it checked and possibly rectified. Sorry for that. :-(
The full diagram can be a little intimidating, since there’s a lot of stuff in it. I’ve been meaning to make a tutorial which starts with the basics and then expands to the other features gradually, to help people understand that the core usage is very simple. The text of the tutorial is already half-written, but it’ll take a while to make all the images needed.
Yeah, it needs some changes to make it more intuitive. And even then, I find it’s still awkward. Ramping just doesn’t work very well with a power-disconnecting tail clicky. So on most of my tail-clicky lights, I still use some of my oldest firmwares… S7 and Cypreus. I like them more than my newer and more general-purpose interfaces.
There is no firmware called Bistro OTSM. It appears to be a customized version of Flintrock’s Bistro HD.
As for differences, the names make it seem like the two are very similar, since it’s just “Bistro” and “Bistro HD”. But they only actually share a few lines of code. If I understand correctly, Flintrock tried to make the user interface very close to the original, but the underlying code differences are so large that it would be a good idea to test the firmware very thoroughly on a prototype of the light.
I haven’t really used Bistro HD much, since it never really worked correctly on any drivers I tried, but I can at least say I already see at least one UI difference between the diagram and what’s documented in Flintrock’s thread. Menu items 3 and 4 are swapped. It’s also likely that the number and details of the mode groups are different, and the manual really should have a list of what the mode groups are.
The difference is about 4000 to 7000 lines of code, depending on which parts are measured. For reference, the original Bistro is only about 1000 lines total. So it’s probably easier to list what they have in common, instead of what’s different: They share a similar user interface, and a few scattered stanzas of code.
As far as I’m aware, Bistro HD has only been used by a few people. This light will be the first time it has been used at a larger scale.
About OTC (original) vs OTSM (HD), the difference is:
OTC (Off Time Capacitor) measures the voltage of a capacitor to determine how long the button was pressed. The driver fully shuts off at each button press, and boots fresh each time the light turns on. The button timing may vary with temperature though, since this uses the analog decay rate of the hardware as a way to measure time. Requires a bleeder resistor when a lighted tailcap is attached.
OTSM (Off Time Sleep Mode) keeps the driver running for a few seconds during each button press, using the control chip’s internal timer to measure time. When power is restored, it continues from where it left off, without rebooting. Timing is much more consistent, but the chance of bugs increases since the driver doesn’t reset its state as often.
Yes, this is required by the license. The exact code shipped on the light needs to be provided.
“Mostly untouched” means it’s modified, and counts as a derivative version. GPLv3 sections 5 and 6 apply, “Conveying Modified Source Versions” and “Conveying Non-Source Forms”. Ideally, the license terms would be resolved in the manual, so the retailers would not have to care about the license. If the manual doesn’t include the right information though, retailers will have to carry the relevant information on their product pages.
But it’s not standard Bistro, not a standard Bistro driver, etc. It’s different hardware with different firmware.
The information may be in other threads somewhere, but it’s not here. The people running the project need exact, specific details… not a suggestion to look it up themselves and make guesses about which information is relevant.
Thanks Toykeeper for clearing some things up. I wanted Bistro in the first place because it is a proven version. Now i can only hope that everything goes well.
To everybody on the no ano list. Please check your mails. If you are on the list but have not get a message from me please contact me.
And for everybody else. Jacky told me that the sale will start this weekend. I have no exact date or time. But i was told Saturday or Sunday.
Perhaps a stupid question so very late in the game, but do we have any known runtimes available for this light with either emitter? I’ve looked at the final manual and see nothing there…
Also, in general, should the XP-L HI run “cooler” than the SST 40 given the less amp draw?
Run time is of course a factor of the amp draw vs the capacity of the cell you put in. If the SST-40 is pulling 7A and you use a 3500mAh cell then you can expect, in theory, about 30 minutes. It will be different as the amp draw will drop as the cell dies so it will stretch out more than the theoretical allows for.
Cool running is again dependent on the emitter and amp draw, is the emitter at it’s maximum and how does it deal with that? The SST-40 does tend to produce some heat up at it’s max of 9A or a bit more, so keeping it down to 7A should help alleviate some of the heat issues. I’d expect the two emitters, in this case, to be fairly similar in heat production. We’ll see pretty soon hopefully.
I hate sound like a broken record here Docc but can you make certain they include both size retaining rings in the box? If I dont like the SST-40 I want to be able to change the LED to a 3535 one.
I talked to Jacky yesterday. If you buy a light with SST-40 a extra XP Centering ring is in the box and XPL lights have a extra SST-40 centering ring. We also talked about extra o-rings. Jacky was not used to this but i convinced him to put a set of extra O-rings in the box.
PayPal should work (I asked a few days ago) but its like raccoon city said. AE takes a extra PP fee. And that will be added ontop of the 27,70 $. I can not say for sure how much it is. This is decided by AE not the seller. But usually it is not much.
