A quad or triple with ramping and a 21700 cell. Something just a smidge thinner than an Emisar D4S and not the absolute scorcher of a Fireflies E07?
A budget and compact 70.2 light with a single 21700 cell?
And I dig those designs, Di_Joker.
- Emitter efficiency increases (less heat & more output)
- Light products that can be configured and controlled via BT/Wifi/remote control/app (already exists, but more mainstream)
- Tint mixing/adjustment/control while light product is in use
- Lights that automatically adjust output based on external factors (light, sound, signals, other sensors)
- New lightweight/robust materials for the body
As we have now seen with other electric innovations, the future of energy lies partly in how energy is stored and how dense this storage is. So new battery chemistries and form factors will play a significant role.
I would like to see next a 2xAA flashlight, where the batteries are placed in parallel (so can be used with one battery like Acebeam UC15), with a constant current driver, as thin as possible. Then the head can be one or two LEDs, with various combinations of emitters and optics.
If LEDs became more efficient, their heat production would go down. So you could get brighter/smaller/cooler lights.
But efficiency can only go so far because light is just another form of heat. If there was an extremely heat resistant led then it could be thermally isolated from the host so it doesn’t burn your hand (or pocket)
True.
(I mean the heat resistant LED part.)
But light isn’t heat.
Even IR light isn’t ‘heat’ - it (and any light) just heats things that happen to absorb it.
You could also define efficiency as “useful (i.e., visible) light out/electric power in”
Okay so heat and light are marginally different but they are both forms of energy. I get what you’re saying 100% efficiency = electromagnet wavelength being sent in one direction so the emitter itself doesn’t absorb any energy and get hot. Still sounds good to me
I think the next big step is gonna be LEP.
- Eye tracking combined with motorized platform so beam points where you’re looking
- Flashlight with lasers and stuff which can paint an ‘outline’ around objects or edges (projection mapping)
- LED directly on shelf (no mcpcb) for better heat transfer
- Use of heat-pipes
- Anode and cathode are both available on + end so why send current through battery tube ?
- Make entire flashlight out of synthetic diamond for better heatsinking
The last item varbos mentioned may seem funny at first, but we are implementing a more human decision approach and “feelings” into our daily innovations. Think about some answers Siri gives you or how the latest robots work.
And therefore I am adding something to the list:
- A flashlight you can talk to. “Hey Olight, can you brighten up the room a bit?” “Hey FW3A_V2, can you shine more over here where I am working?”
Imagine the use cases going forward…
Im ashamed to say that up until the flashlights can feel pain and become jealous and questioned the synthetic diamond part, I believed everything was real. You can tell Im no expert in flashlights.
Pretty easy build today. Convoy S21A, XHP70.2
Where did you get that reflector? It’s beautiful! What’s the beam like?
Ledil Boom reflector. Beam is super floody but even, no donut hole.
I actually prefer the XHP-50.2 using the stock OP reflector better.
I still have a soft spot for 1xAA lights (especially if they also accept 14500 Li-Ion cells). I’d love to see more development of the perfect BLF 1xAA special with a fancy open source driver and a good clip, very low parasitic drain and/or mechanical lockout, and compact size.
I also think there’s room for a BLF special edition headlamp. Zebralight is awesome, but they’ve ruled the market for far too long!
I’d be interested in a few things: (some have been mentioned, so +1 on those)
-Bike lights
-Buck+boost drivers
-Magnetic attaching+onboard-storing diffusers (90deg or side switch lights)
-Headlamp with large LES and high CRI (linear array of Nichia 757?)
-RGB color ramping aux LEDs
-USB or BT programming connectivity
-LEP thrower
-Diecast designs
–14650 based EDC with A6 style FW (think 15mm longer ET D25a)
