I’d be happy with any 4500K bin below BBL
I’m down for 7x 219C SM4050E & 7x SW45K & 3x SW30
Diference between sm4550e and sm4070e ?
I prefer the 4000K version because it looks so sunlike at night but I would be down with 4500K rosy version also. Any chance you can get the 4070E, because with the reflector or optic on, it will likely bump the duv above the BBL like I’ve seen with the SST-20 FA3/FD2 tints? I think Clemence was selling the 4070E version previously.
^ good point, similarly for 4500K - sm4570e would be preferable.
What’s the appeal of being below the BBL? I know that means it’s rosy, but why intentionally move away from the BBL?
For me I actually like it slightly below BBL since I’m not a fan of the heavily rosy tints. It’s more of a subjective matter but I think for most people, yellow and green (above BBL) is considered ugly so moving in the opposite direction is desirable.
When I edit photos, I find that adding just a slight tint of red usually makes the photo look better. Of course this is also subjective.
I usually just associate that warmer tones as being more pleasing so maybe it’s a psychological effect. Think sunsets vs midday photos in landscape photography for example.
Why not. BBL is a reference and something we get used for long (depending on someone’s age) because of filaments bulbs, but it’s not an absolute requirement.
Most people are so get used to it that deviations from BBL are noticeable but above, on, or below BBL are a matter of preferences.
BTW, The cosmic microwave background frequency spectrum is a perfect black body at 2725 K
I also don’t like overly rosy, but as SKV89 mentioned a reflector usually pushes up the duv so choosing a bin further below the bbl should hopefully balance it out. Either way, any 4500k under BBL is good with me.
What does that mean? lol
The ideal CCT is 2725k?
In for 20 of the Nichia 219c sm4050e 4000k
If you’re willing to sell some of the Yuji 5mm, I’d buy a few. 5600k if you got any.
Sorry don’t have any.
Are the sm4050e r9050 or r9080?
According to the datasheet, I see r9050. These are just the minimum values. It’s very possible to get a bin as nice as the r9080 Fingers crossed.
My mistake, i meant between sm4050e and sm4070e
Thanks!
Hi,
I have some questions:
- May I know the unique pro/con of the sm4050e/sm4550e compared to the Nichia 219B 9080, SST-20 FD2, or other highly recommended emitters?
- What is the difference between the 2700K and 3000K? They are so close together, is there a difference that people could preference between these two?
- What do you guys rate your preference when choosing and LED? (TINT:CRI out of 100) I am still learning about the importance of tint, so my preference is 60TINT:40CRI
- What are popular types of optics and how does each one affect the tint?
- How does current affect the tint?
- In relation to tint, What is the pro/con of a PWM driver compared to LINEAR driver?
I think I will purchase the top ~10 LEDs (including some “good CRI, bad tint” ones like SST-20 FB4) and put them all in a reference platform so I can finally end my misery.
I believe the 219C outputs more than the SST-20 95CRI, which is already noticeably brighter than the 219B. The 219C will likely have between 90 and 95CRI and R9 of 60 or so, whereas the SST-20 and 219B 9080 will have CRI of 95+ and R9 of 80+
Almost all of the warm or soft white led light bulbs I tested whether from Home Depot, Lowes, Costco, Ikea, are around 2700K. There is a noticeable difference between 2700K and 3000K
Tint 60/ CRI (R9) 40 is my preference too. Some of the 90CRI 219C and LH351D 4000K I’ve seen are so far above the BBL that everything looks lime color. yuck. R9 is more important than CRI because red rendering is most noticeable.
Reflectors usually raises tint more than optics. I have a 4000K 5A XHP70CRI that is super rosy without reflector and looked super yellowish with reflector, probably bumped it up by duv of +0.015 if not more. The MF01S SST-20 4000K without optics is super rosy also and with optic, it straddles the depending on current. I think the optic bumped up the DUV by about +0.007 if I remember correctly. This is the reason why I hope Azhu can source some 4070E instead of 4050E to ensure even with reflector and optic, it will not go above BBL.
Most emitters get rosier with higher current. SST-20 tint varies the most.
PWM can maintain the tint at different output levels. My TO46R with SST-20 has nearly the same tint at all output levels.
