WTS/GB: NICHIA 219B NVSL219BT-V1 R9080 EMITTERS! sw45k, sw40, sw35, sw30
That is my understanding.
However, it is also my understanding that most device manufacturers prioritize consistency versus a particular tint deviation, and if they are going to design to a specific tint deviation, they are likely to be conservative and prefer to stay close to the BBL.
Therefore, it is my assumption (but only an assumption), that emitters that are within 3 MacAdam steps of the BBL usually get sold in SM403 bins, meaning SM4050e bins should be less likely to contain SM403 emitters, and SM4070e bins should be less likely to contain SM4050e and SM403 emitters.
(1) Let me try a comparison table to help
219B SW45K 219C SM4050e* SST-20 FD2*
CRI 90 min 90 min 95 min
R9 Value 50 min 50 min No Spec
Ouput at 700ma 200 or 220 lm min 220 or 240 lm min 193 or 205 lm min
Tint at rated Current Very rosy Rosy?* Very slightly green to slightly rosy*
Tint at high currents Rosier Rosier? Rosier
* Most common bins (SM403, FB4 etc) have been reported to be slightly green
Based on BLF tests, it seems Luminus may be slightly more conservative than Nichia, so the output difference may be smaller than the specs suggest.
(2) There is a noticeable difference side-by-side. Not huge, but I definitely see the difference between the 3000K lights in my kitchen and the 2700K lights in my dining room.
(3) This really is a matter of preference to figure out on your own, but your attempt at balance makes sense
(4) Total Internal Reflection (TIR) optics seem to usually do a better job of smoothing tint out across the beam than reflectors. Reflectors usually produce a more defined hotspot and spill area that I find makes a versatile beam.
(5) As in the table, in many emitters, increasing the current tends to shift the tint to be rosier, but I don’t think this is universal to all emitter families.
(6) A PWM driver will have fairly consistent tint and efficiency within a single power channel. A current controlled driver will experience more tint variation, but should be more efficient at lower outputs.
Yes I’m aware of that particular sales thread but this group buy is for the r9080 variant.
UPDATE: Not making any promises but looks like the sw30 r9080 is very likely to happen… :slight_smile:
Awesome,
Please reserve:
8pcs sw30 r9080
Added.
Just so we don’t get our hopes too high on the 219B 3000K. I bought some NVSL219B-V1 sm303 D200 R9080 from LEDrise.eu and measurements I got in a Convoy S2+ triple on highest output:
CCT: 3372K
DUV: 0.0011
CRI: 95.2
R9: 84.5
Rf: 93
Rg: 102
It is above BBL so noticeably more yellowish than the SST-20 3000K or E21A 3000K. Maybe a lower output D180 would have produced a more rosy tint that we are all after. I’m hoping for the best since I’m on the group buy list but just letting everyone know. I would have more interest in the 2700K since that one is to date untested and might give us a pleasant surprise.
Yep I’m hoping the test results will come back favorable if my order goes through. Just awaiting confirmation right now.
My rep informed me that sw27 is unavailable at this time and there’s no projected ETA if those will be available anytime in the future so the outlook on that is dim. Sorry guys.
As for the 219c sm4050e, I’ve submitted my request and awaiting a response. Will followup by Friday if I still don’t hear anything.
I might also be getting a small batch of sw35 in addition to the sw30 if that comes through.
Can you ask for the sm4070e also?
sm303? Or did you mean sw30? Cause the sm303 is from the 219c.
I have :). Awaiting a response on the 4 bins I inquired about: sm4050e, sm4070e, sm4550e, sm4570e
Good catch. That’s exactly how it is labeled from LEDRise. 219C doesn’t have 9080 so I’m pretty sure it is the 219B.
That’s suspicious then… haha. Would it be possible they might’ve labeled it as a 219b r9080 when it’s a 219c r9050 that ranked higher in CRI?
The difference is black and white (literally, just look at the LED base) :slight_smile:
Compared the LED base with that from Azhu’s sw35 and is identical.
Add me for 15 sw30 r9080
Thanks
Yeap, could take 10 of each
UPDATE: So in regards to the 219c, right now only the sm403 bin is available. None of the other options are in stock. I’ve requested to be notified in case they ever do become available. I also made a mistake and didn’t realize that the sm4550e and sm4570e bins don’t come in 90+ CRI so they will be dropped out of consideration.
219b sw30 and sw35 are still likely to happen. Will keep you guys posted on those as more info becomes available.
Thx Andy
EDIT: if 219C is out of the game then i’d like 10 x sw35 instead
Well, since the 219C fell through, put me down for 6 of the 219b sw35 r9080’s.
