Are big pictures in threads annoying? Vote yes and get a free half bottle of beer. S&H only $99.
I always never have deliberate ulterior motives.
Always be afraid trust a flasholic bearing chains gifts.
Thanks for the tip zak.wilson, never used the advanced tab anyways. I guess some editor documentation would be of help.
:smiley:
Dale, I’ll take it! Go ahead and PM me that image file. :partying_face:
The following is to report something I already noticed in the past with regards to the max-width property. Let's see an example with a funny gif:
With 336 × 210 pixels of actual resolution I've scaled the gif at 3x its per axis resolution: 1008 × 630 pixels. Also, the max-width property is set at 100%. You will see the upper, scaled gif with wrong aspect ratio in small screens (with less than 1008 pixels of available space for the forum box).
Is it possible to set a youtube video to a % of column width.
I tried a few different ways and all I seem to be able to do is set the width in pixels.
Thanks for the help,
All the best,
Jeff
A test from youtube using video:FT 001 - YouTube width:400
If you watch this turn the VOLUME DOWN first.
Trying width % video:FT 001 - YouTube width:90%
Gets me 90 pixels
jeff51,
Setting the width in % as you did in the Simple Post Editor does not work, also tried a max-width attribute to no avail.
Let me say I've always been using fixed resolutions for videos via the Advanced Post Editor. Any video's optimal resolution can be obtained selecting “Nerd statistics” in the drop down right click/long tap video window menu.
Just tried setting the video width in % in the Dimensions left, horizontal box, using the Advanced Post Editor. It actually works, albeit it will look garbled while editing and Preview gets broken. Here it is set at 70% width:
Well, the width porcentual parameter does not work with videos; the forum engine fails to actually detect the correct video parameters and set its height accordingly when used that way. My advice, thus, is to set an actual valid video resolution. Here it is at 854 × 480:
What happened to max-width? All of a sudden, if I use this syntax, it ignores the % I entered and just shows the image at 100%.
https://budgetlightforum.com/t/-/58895
Not sure that it answers my question. There is something wonky going on when using the ‘max-width’ operator.
Like this?
Test
For some reason I get an error message when trying to insert an image into this thread using the image icon in Simple Post Editor quick reply box:
Firefox says:
Chrome says:
It would be helpful if you posted what you inserted. Perhaps leave off the < > delimiters so that the browser does not parse it as html.
I did not insert anything. These errors pop up the moment I try to click on the “Insert Image” icon.
See screenshot: https://i.imgur.com/XTfZ5w5.png
Perhaps you can try a different browser, or the advanced editor:
As I mentioned before, this happens in both Firefox and Chrome, only in Simple Post Editor, and only in this thread. Any other thread - it works fine. Just found it very odd.
Does anyone else get the same error when trying Simple Post Editor in this thread?
Hmmm weird. Works for me (sorry, I hate that kind of answer from admins). Anybody else can confirm or deny this?
I get exactly the same error - Firefox
Thanks for reporting.
Dunno, it works for me in Chrome and Firefox. Please try clearing the browser cache or force-refreshing the page now that I made the CSS tweak mentioned before.
