Added a second emitter group. And added two relays, as the current eventually will be to high for a switch to handle.
The second quad is XP-G2. 2x S4-5D 4000K and 2x S3-3A 5000K
The first has been upgraded to 4x XP-E2 P3 A2 amber leds
Next step is adding the 3A charger circuit, and connecting the two other 18650 bays.
I’ve been out of town with the birthday boy but on Sunday I modified the Arctic Cat I’d been working on, condensed it from 650 pounds to about 44.62 ounces.
This is a Ray-O-Vac Hunter Lantern 398, purchased on eBay, new-in-box. The Texas Ace Calibrated Lumens Tube measured 20 lumens with original bulb.
It would have used a 6V lantern battery, back in the day. It can also use eight Ray-O-Vac "#2D" cells (according to the instructions). However, regular D cells were too big and C cells were too small. The Ray-O-Vac #2D cell must be something unique. Doesn't matter, I will use 21700 batteries.
An EBLCL Maglite LED bulb (link) was installed in the bulb holder, giving it about 130-150 lumens, measured out the front (see runtime graph). A blob of solder was added to the spring, for better contact.
A dual 21700 carrier was hot-glued and wired into the main housing.
Two Samsung 21700 were installed in series (the EBLCL Maglite bulb is rated up to 9V).
DC-Fix diffusion film was added to the front lens to smooth out the beam.
A runtime test was performed, to make sure everything is working.
That’s really cool, Terry. Awesome how it still looks stock (except for the film) and I’m assuming everything can be undone?
Also, does that bulb have low voltage protection? Based on the runtime graph I’m guessing so, but I’m not sure how that would work based on it handling 3-5 D batteries.
The cut off voltage is 2.5V. Just tested another EBLCL bulb on a variable power supply. At 2.6V - just a little bit of light - at 2.5V, nothing. I've used that bulb in about six other vintage lights, no problems.
Ohhh. I’m sure I don’t need to warn you of this but I’ll just throw it out there… be careful with that cutoff. With your cells in series, each one could get down to 1.25V
I’d be curious to see if the light is equally bright with only one cell (or with them in parallel for extra runtime). That way low voltage isn’t a concern. With such a wide voltage range and flat runtime graph, I’m curious if there’s a small stepdown circuit inside. In which case, running cells in series (higher voltage) actually might not increase brightness.
Just did an experiment with a power supply and the Texas Ace Tube. At 3.7V (approx one cell), output drops significantly (from two in series at approx 7.4V). Would only get worse as the single battery level drops a bit.
