Simon, what’s the size of the MCPCB? Can similar sized MCPCB’s be found elsewhere??
Simon_Mao
(Simon Mao)
August 21, 2019, 9:49am
1701
uh,it’s just virtural number :person_facepalming:
Ryzbor
(Ryzbor)
August 21, 2019, 10:42am
1702
[/quote]
Anyone knows if this light will have a clean beam pattern with the 219B based on their experience?
Will the carclo triple/quad compatible model follow soon after the release of the reflector model?
oweban
(oweban)
August 21, 2019, 11:56am
1703
Noice, so yep, can drop some sw45ks into that. 2A each is fine.
Thanks Simon
Di_Joker
(Di_Joker)
August 22, 2019, 6:10am
1704
Maybe someone managed to find a suitable TIR optics for Convoy S11?
Can you perhaps measure the reflector? I have a S11 on the way, might want to make a quad mule out of it.
oweban
(oweban)
August 22, 2019, 6:35am
1707
diameter 28.5mm
height 20.7mm
diameter of bottom hole 7mm
weight 10g
suitable for XML2 XHP50 XHP50.2
I measured it up ages ago when looking for options - I think I found a ledil and a carclo that would be close , but still not 100%.
Edit: from memory, the opening at the head is 25mm, in case you find a TIR with the “shelf” bit.
A mule with TIR optic? A mule is a flashlight without any optic.
I didn’t say I want to install an optic. I want to install a quad MCPCB and a spacer, together with a lens and some film to diffuse the light a bit.
oweban
(oweban)
August 22, 2019, 6:46am
1710
Simon would you consider manufacturing a P60 style host in 21700 format? The design in 18650 was flooded on the market. But now good host have nearly dried up and no one every built it in 21700 format. If a host was built to your quality standards I’d replace every P60 host I own now. SF compatible except tail cap, as body diameter is increased to 28-29mm’s.
Kiriba-ru can make spacers. He just needs specs. And his prices are reasonable!
oweban
(oweban)
August 22, 2019, 7:02am
1713
RelakS
(RelakS)
August 24, 2019, 3:25pm
1716
The M21A has the same narrow beam and weak flood light as the C8+?
As far as I can see, if the beam pattern is the same, the brightness is doubled compared to the C8+ (8x7135), which I could be interested in
Yokiamy
(Yokiamy)
August 24, 2019, 3:43pm
1717
RelakS:
Yes, because it is basically the same light with another name (due to the 21700 cell)
The output will be more thanx to the SST40 led and more powerful driver.
RelakS
(RelakS)
August 24, 2019, 3:45pm
1718
Yokiamy:
Thank you!
I was not sure if the mirror is the same.
I assume it’s like the biscotti driver situation. Some old, some new, big pile, chosen at random. Who knows what you’ll get.
