Lightbringer:
Oh, and it charged my phone just fine. Dunno about “The IPhone Problem”, but my normal phone worked fine. Was at like 36% or something, topped off, drained the PB2S down to 65% or so. Ymmv, of course.
Two fold. Maybe one-and-a-half fold.
1) The PB2’s low current threshold (290mA, according to HKJ) would prevent iPhones from fully charging to 100% before it shut off.
1.5) The USB output coding didn’t correspond to full “fast” (~2A) charging. Of course, iPhones don’t speak QC either, but newer ones do speak PD, so the PB2S appears to address that situation.
I’ll eventually pick up an S after I find a way to pawn off my PB2. I’m a sucker for detailed displays, and am done buying sealed power banks that are effectively trash after their cells expire.
maukka
(maukka)
August 22, 2019, 9:39am
22
TheIntruder:
Bmengineer tested the PB2S and it cuts off between 20 and 30mA in the normal mode so this is fixed. For even lower charge currents there’s the low power mode.
fran82
(fran82)
August 22, 2019, 3:13pm
23
Where is the info about the low power mode?? (Below 30mA)
maukka
(maukka)
August 22, 2019, 3:21pm
24
In their promo video:
Here it is running for 16.5 hours straight in low power mode with a 10mA load (credit to bmengineer)
fluke
(fluke)
August 22, 2019, 4:04pm
26
What is the standby current?
PB2 was terrible.
fran82
(fran82)
August 22, 2019, 8:47pm
28
I am starting to love the PB2S
Hope the price drops
Thanks for showing me the info about the low amps mode. Great!!
fluke
(fluke)
August 22, 2019, 9:02pm
29
bmengineer:
Patience, grasshopper.
I walk the rice paper gently.
Klotski
(Klotski)
August 22, 2019, 11:17pm
30
Lightbringer:
I just got one, and it’s nice! The “official” link is
XTAR PB2S 18650 & 21700 Fast Charger & Power Bank
which has anigifs to show how it charges/discharges.
True, it’s bigger’n the PB2, but this donk fits 21700s, too, that’s why.
Hell, today I needed to charge a 26650 (Cometa) and it fit it just fine. Sure, just one cell only, and the cover won’t fit, but to be able to charge even a moose like that in a hurry? I’ll live with “larger”. :laughing:
And there are 2 separate independent channels, so you can put one nearly-topped-off cell right next to one that’s almost dead, and there’ll be no problem.
The side-button lets you click to see the connection spex, then for battery 1, then again for battery 2.
Where did you get yours from? i see
This is my first XTAR charger, and I’m happy with it.
Lightbringer
So where did you get yours? I see Illumination Supply now has them for $17.52
UserM4
(UserM4)
August 28, 2019, 6:53am
33
If anyone’s interested, I did a charge comparison against a wall charger and another power bank.
https://imgur.com/a/veExc6B
@UserM4 thanks!
The PB2S is already out of stock on Aliexpress. The owner told me the red ones should be available next week, the black ones will be delayed.
SwissFlashy:
It is back in stock!
Just ordered a res one. Thanks for the heads up!
david_opp
(david_opp)
September 11, 2019, 10:05pm
37
Does someone have first impressions of the magnetic latch? Are the magnets strong enough to hold it securely in place even when tossed in a backpack?
Yeah, you need to actually pry into the crease between door and body to open it. It’s not likely to just pop open on its own.
Cythras
(Cythras)
September 16, 2019, 3:06pm
39
Illumn has been advertising QC 3.0 AND PD charging, but the official specs don’t mention a 12v output. Judging from the OP, I suppose it doesn’t actually support PD?
Check out this review as it talks about the 12v output
