【convoy】H4 and B35AM options are updated
Simon would you consider manufacturing a P60 style host in 21700 format? The design in 18650 was flooded on the market. But now good host have nearly dried up and no one every built it in 21700 format. If a host was built to your quality standards I’d replace every P60 host I own now. SF compatible except tail cap, as body diameter is increased to 28-29mm’s.
Kiriba-ru can make spacers. He just needs specs. And his prices are reasonable!
https://i.imgur.com/VPExcQ5.png (in inches, though)
:wink:
Thank you!
And thank you too!
The M21A has the same narrow beam and weak flood light as the C8+?
As far as I can see, if the beam pattern is the same, the brightness is doubled compared to the C8+ (8x7135), which I could be interested in :neutral_face:
Yes, because it is basically the same light with another name (due to the 21700 cell)
The output will be more thanx to the SST40 led and more powerful driver.
Thank you!
I was not sure if the mirror is the same.
I assume it’s like the biscotti driver situation. Some old, some new, big pile, chosen at random. Who knows what you’ll get.
What size is the head?
I have some 20mm and some 25mm round stock aluminum i can turn into a spacer. Just need to cut it the right height and drill a hole in the middle.
I’ll do some measurements and draw it up tonight.
Simon, please feel free to correct anything I have wrong :slight_smile: (reflector shape isn’t accurate, though)
The main thing I don’t have in there is the indentation in the pill itself - as noted in this thread on /r/flashlight , he made a spacer with a cutout for the MCPCB and an extrusion to fit in the existing MCPCB “hole”.
Measurements in inches in image below.
Kiriba-ru made me 2 versions of the S11 spacer based on the dimensions posted to the Reddit thread. One was pure copper, the other was a copper core with a brass support ring to keep the optic in place.
Dare I ask how much it cost? :slight_smile:
2019/8/26
new flashlights
S12
M21B
M4U
I like the looks of the S12, that tailcap :+1:
How does the beam look versus triple TIR, e.g. Carclo?
Very welcome updates to the other two as well!
S12… :heart_eyes:
What a beauty
My precious… :smiling_imp:
I would really like to see a beamshot of the S12… Very interested in one!
Very interesting MCPCB though… might look into sense resistor mod for it too cause more than 2A per emitter would be good.
will the S12 fit the Vapcell 4500/ Lishen LS21700SF cells?
