There’s nothing wrong with it, but I dislike mode memory most of the time and prefer an option to disable it. So Simon going from programmable firmware with options (Biscotti) back to fixed modes and fixed memory drivers seemed like a step backwards. If he had launched this one with an Atinny25 based driver with Crescendo, it would have also opened up the possibility to flash it with Bistro or other Atinny based firmware.
Edit: So it looks like the S12 uses a 22mm driver, if it’s the same 6A driver Simon already has. Kaidomain sells a 7135x12 22mm driver with Atinny13. Could have potential to flash something better. I’d like the S12 a lot more with programmable firmware on it.
Yes, i agree what’s up with it?
It seems he launched several new drivers, but it feels like a step backwards, at least biscotti offers a choice
Also i saw new drivers that seem to have solder pads to make a fixed choice ?
Simon, please offer more drivers with Biscotti, or even better the A6 firmware with the possibility to select following mode or previous mode (Or Bistro or Anduril or another option to reflash your own firmware such as with newer Emisar lights)
Everyone has his own preferred mode
Looking forward to this! Please have option to start on moonlight always and no PWM. Also please design to fit 16mm mcpcb for easy modding because so many boards are 16mm including the E21A and Optisolis. I will buy a bunch to mod if it has the above.
Simon’s thing these days is all mode memory all the time, so I don’t know about that starting on low thing. I wish Simon would just copy Reylight’s AA driver. Moon-Low-Med-High with 8 taps to enable/disable mode memory.
Snap. I bought the Ti LAN because of the driver. Now I don’t even want to use it for fear of damaging it :person_facepalming: . It’s one of the most expensive light I have.
If he makes just 100% after 2 or 3 click, then there could be 4 regular modes and 1 “turbo”. Then make temp. limit to 65 degC and ability to disable memory and it is all I want. And I guess most of us.
I only ever want mode memory on e-switch lights where there is also a shortcut to at least moonlight, and preferably turbo or even more like on Anduril and Zebralights.
