I can buy standard 5.5 × 2.5mm DC power connectors cheap as chips and turn powerful unused laptop bricks into valid power supplies for this application.
All of that USB PD @#$% is an unnecessary evil here, imho. How is it going to save money? How is adding USB PD electronics plus type-C connectors gonna make this cheaper? It's quite the opposite. And not everyone has a PD supply, much less a really powerful one.
As everyone else I also am somewhat biased. But you can see the points.
With the long list of features this device is already a challenge for the price. I prefer to keep things simple.
Can you use old laptop bricks? Absolutely. It’s a fantastic use for them if you still have them lying around (although, obviously they will be larger and heavier than the chargers we’re seeing hit the market now, unless you’re planning on going out and buying a new one).
Can you use new laptop bricks? Not as much. Many of them are switching to USB PD.
I didn’t claim it would save money.
I said that it would make it possible to use it with USB Type-C chargers (which are relatively common at this point, and are quickly increasing in popularity, particularly in the ~60 W range with laptops moving to USB PD and new technologies like GaN chargers hitting the market).
I said that if it’s 5.5 * 2.5mm DC, for me personally it would end up being stuck on one dedicated charger (as the 5.5 * 2.5mm DC chargers that I have are in use with their devices that they came with), instead of being able to be plugged in around the house (as I have a plethora of USB PD chargers, and the number is increasing).
I also didn’t directly mention this, but USB PD is also a positive if I take it with me somewhere, as then I can just bring one USB PD charger for everything or plug in to one locally, instead of having to bring a USB PD charger and a charger for this as well.
Don’t get me wrong, I see why people would want 5.5 * 2.5mm DC. I just personally have a strong preference for USB PD (especially from a convenience standpoint).
Well I have no usb pd here and lots of 5.5 * 2.5. But I am on board with usb PD. It sounds like PD is looking forward, and 5.5 is looking to the past. I always vote with moving forward toward good new tech.
Even if you go with USB PD, couldn’t there be a 5.5 * 2.5mm barrel connector wired in parallel? Write “Do Not Connect Both At Once” on the back or switch them with MOSFETs for automatic power source selection.
I also don’t have a powerful PD PSU.
But I am sure I will buy one at some point anyway because I believe it’s the future power socket for many devices.
I’d strongly prefer the BLF charger to be a part of this future as otherwise it will force me to lug around a dedicated PSU which is simply inconvenient.
Also, USB input would allow me to charge cells from a car outlet.
Or a bus. Or a bench. There are way more USB outlets scattered around the public places than AC ones, let alone barrel DC.
Preparing for the future seems reasonable to me, especially since it’s been stated that a wider market other than solely BLF is being planned for.
@Phlogiston - “Even if you go with USB PD, couldn’t there be a 5.5 * 2.5mm barrel connector wired in parallel? Write “Do Not Connect Both At Once” on the back Smile or switch them with MOSFETs for automatic power source selection.”
Again, to me two connectors is also reasonable and a good idea, although I feel the addition of automatic power source selection is not necessary.
OG
Charger is only for individual cells (1S), nothing assembled in series.
Just the beginning still. Blue is finalizing specs and discussing with mfgs soon.
I do not mean to be disheartening but, fellows, please keep a look at the already long list of features and capabilities for the target price. Maybe some of you would prefer a “deluxe” version, don't you?
At this point BlueSwordM may want to start asking some really budget manufacturer like LiitoKala. I could also do it, @#$%.
Joshk, balance charging? That feature requires quite a different design than the usual for independent slot devices. It would require to set any contiguous slot “in series compatible” with the previous one, or else stuff would blow up. Someone already did that with a Lii-500 and… magical smoke.
I don't mean to be impolite but I still have no answer. Please can someone confirm if this feature will be part of the specifications or not? Thank you.
@Lux-Perpetua, a partial feature has been written already in the form of a charger non-reset disabling between 5-10V, to prevent charging to restart, or during a sudden loss of power during charging. Basically, solar panel
One last minute change could be added, as someone else(and you directly) discussed in a PM at SecondLifeStorage:
Basically, you could have the ability to change chemistry on boot, NOT reset on any power loss(forceful battery removal before charging completion to your settings or blackout, same thing really), and will not resume charging unless manual input is used.
Only for lithium-ion chemistries though. NiZn is so niche it doesn’t even matter, and even then, charging with NiMH parameters isn’t dangerous.
I maybe need some help. I’m not too adept dealing with direct OEMs like DLYFull.
Reminds me of the start of my 1st Gen GB.
Ok guys, so as I expected, it would actually be better to make the charger out of aluminium since it would require way less units to move compared to plastic injection moulding(at least 40000pcs per year and optimal would be 50000pcs per year).
So yeah, we are going with aluminium.
49$US target price is set, which includes the power supply.
