I ordered two lights in separate orders the same day,
Both were marked shipped that night!
Both numbers track in China, which means just sit down and wait.
I would like to know too…mine broke! Anyone know?
Harbor Freight sells an assortment cheap.
https://www.harborfreight.com/225-piece-nitrile-o-ring-assortment-67677.html
https://www.harborfreight.com/382-piece-o-ring-assortment-67554.html
https://www.harborfreight.com/225-piece-metric-nitrile-o-ring-assortment-67609.html
https://www.harborfreight.com/397-piece-metric-o-ring-assortment-67580.html
Neal posted on FB that the FW1A will be available next month, in addition to 18350 and 18500 tubes for both it and the FW3A.
I’ll bite. What is the FW1A?
FW3A, but with a single emitter and reflector design instead of a TIR optic.
Thanks!
Does this mean they are lengthening the head to get the taller reflector to fit?
FW3 was my favorite light when I got it.
Then my Fire Flies E01 showed up.
I really love this light
only 1” longer, lit side switch, the throw on it is great. Rivals an L6. Not in total lumens of course, but the narrow beam penetrates like crazy. AND it can stay on turbo for a long time, handles heat very well.’
Too bad they stripped down the UI. Have an E07 on order, I know it does not throw that well, but smaller and 6900 Lumens.
I may have a new favorite light.
I’m not a facebook guy, can you link more info about the FW1A? It sounds like a must have.
There is no more information on the FW1A at this time.
You don’t have to go to facebook for info on this, i’m pretty sure all information will appear in this forum as soon as it is available.
Isn’t that light much larger? It’s 21700 sized.
The Lumintop EDC18 should be the side switch version of the FW3A. Same size, but can use protected cells, same UI, same Leds, lighted side switch, deep carry pocket clip, magnet in tail, etc…
I don’t pocket carry - pockets are full of guns, shield case and so on.
In a small belt holster, the difference in size is negligible, and the weight is about the same.
The E01 will run way longer on high, the FW3 quickly becomes too hot to hold.
The E01 has a narrow well focused beam, which has a throw that rivals an L6, while the FW3 is totally flood.
That being said, I have like 5 of the FW3 lights and they are great, the copper is stunning.
But I find the E01 more useful.
Are we sure it’s got a reflector and not a single TIR?
If it has a reflector, I really hope it’s the same size as easily available Yajiamei Optics. Iove playing with optics and different LED’s.
Don’t like the stupid ring around your LH351D beam in a reflector? Pop on a beaded optic. Enjoy the magic!
I would probably prefer a single TIR optic, but I’m excited about either.
I was hoping for a TIR as well, will have to see what fits.
I’ve always liked the large hotspot in good single TIR lights. We will have to wait and see. I wonder which LED will be used, and how bright it will be.
Maybe they can use a big fat MCPCB like in the Ti model and fit a TIR or reflector by just swapping MCPCB size. Wishful thinking…
https://www.harborfreight.com/225-piece-nitrile-o-ring-assortment-67677.htmlhttps://www.harborfreight.com/382-piece-o-ring-assortment-67554.html
Those are all way too big to replace the pocket clip/inner tube o-ring. According to my measurements I think they are around 18mm x .5mm. I have no idea where to source them, but now I need two. And any bigger, the light won’t work. :person_facepalming:
