Dale, I know… but with drivers are doing so much more now days than a couple of years ago… setting up a standard UI would be nice since it would make the lights easy to switch between.
Right, but how do you make a standard UI fit all the different drive methods? Direct drive, constant current, boost, buck, boost/buck . I mean, I don’t know how to write code or anything but I do know it’s a much more complex issue than most tend to think it is. You have to write the code to fit the programming chip, available memory and available pin legs, it all changes between the varying driver designs so how do you do it? And what’s in it for those that know how? More accusations? More blame? Certainly no big paychecks…
Following…
SST20 is in my head… Bluesword is right, hi cri super thrower
Oh, that means the flashlight’s USB port isn’t used for reflashing the driver firmware. However, the driver still has flashing pads like the D4v2 does, so it can be reflashed in the same way as other Emisar lights. In other words, it still requires a pogo pin adapter… a USB cable alone isn’t sufficient.
It can definitely be tricky to make a single program work consistently on a variety of different hardware. It involves all sorts of different abstraction layers and modular designs to allow the front end to remain pretty much the same regardless of what back end it’s running on. I’d say that’s why they pay me the big bucks, but … the bucks aren’t big.
Regardless, I think this will be an interesting light.
Looking forward to it. My 10th Emisar and an Epic one at that!
I find myself agreeing with you so often on here. Ever since I got my Mini One Ti, I think the USB port in the threads is great. This should be quite the light!
I’m skeptical about SST-20 compatability. If Hank is using the white flat, the focus will be a lot different than for any domed LEDs, at least if people’s C8 mods are anything to go by.
A shame Hank almost certainly can’t use CULNM1 in this…
It’s probably too difficult to procure a good flux bin batch of the CULNM1.
Or find them at all if they are already being phased out.
I think it means that it has Ramping OS without updates and that with the pads you can install Anduril for example.
I mean, they don’t have to by set up with a flap.
A flap is easier to design, but they could just be sealed instead (like what phones do). It just means you can’t plug it in until it dries.
Exactly.
Which is why FSM is such an amazing beast.
Hank said the head is 70mm which means it should be over 600kcd
Edit: It’s 550+
Edit: It’s 600+ now so I guess I was right
Any news on when it will be released?
Soon™
Interested.
Interested.
Interested!
Sign me up for 1 :-p
(interested)
Hank if you see this thread we would love an update on this project
