UPDATE: sw30 and sw35 are arriving today. All those that expressed interest have been PMed.
PP sent!
UPDATE: I have 35 pcs of sw45k available. First come first served.
I’ll take 10pcs sw45k
I’d like 6 sw45k.
I want to purchase 6pcs sw45k please
I’ll take the rest of the sw45k. (13 pcs?)
UPDATE: Out of sw45k. Will try to get more in the future.
Thank you very much for doing it for us. If not you I would have no opportunity to purchase these gems.
Payment sent. Thanks!
UPDATE: Added some new test results from today for a better comparison between various emitters and bins:
I compared my FW3A SST-20 FD2 to my modded FW3A SW40. The Nichia kicks ass with the tint, by far. It obviously has less throw, but I prefer the more floody beam anyway. It’s a triple after all… The SST-20’s will be replaced by SW35’s when they arrive.
Are you sure that is the SST-20 FA3 bin? How were you able to obtain those? Also FA3 shouldn’t be that green. That duv looks like it is FB4 tint.
I was hoping the SW30 would be rosier than the SST-20 3000K. I measured SST-20 3000K at –0.002 with carclo triple optics at high output modes. What kind of current were those DUV measurements taken at?
I traded a fellow member some of my 219b for the FA3. He said they were obtained direct from Luminus. Maybe it was a bad measurement but in person, I don’t see any green. Looks very nice actually.
These tests were done at the 2nd power level for the Lumintop Tool AA. They were measured about 12 inches from the head. Most measurement values are around 700 lux with the exception of the SST-20, which was closer to 1200 lux.
I have a few 3000K SST-20’s from a gb on BLF that are supposed to be HD2 bin, but at low to medium currents they are greener than the 3000K LH351B’s * that I also got from a gb on BLF. At high current, around 1.5A, they go rosy beautiful tint. I think the SW30’s will be a better overall tint performer just by the performance of the SW40 vs SST-20 FD2.
SST-20 tint varies tremendously with current. I have some HD2 bin and even at low levels, they are not as green as many of the other 3000K lights I tried. I don’t have any LH351B 3000K to compare with though. The HD2 is supposed to be rosier than the FD2 tint according to the chromacity chart.
Tool AA on 2nd mode should be very low current. In that case at higher modes, the tint for all of these should get rosier I assume unless it uses PWM.
I’ll re-test the SST-20 tonight at higher modes to see if it helps with the Duv. I agree that the SST-20s are very current dependent when it comes to tint. One thing is for sure, the flux on these are so much better than the 219b. Even if it was slightly green, I can see it being a trade off for more lumens. Like I said earlier, even at the 2nd mode level, my eyes don’t see any green despite what it says on paper. It looks very similar to the sw40. Will check the emitter again tonight.
those duv shots are outstanding!
now I know why I felt my sw40 9080 needed a lee 1/8 minus green
azhu, just curious what did you end up getting to be able to measure this?
I’ve never tried the minus green filters. Are you cheap to order?
I figured out how to use my i1DisplayPro to measure the CCT and Duv values.
