Great review!!
With regard to the included special micro USB cable you did mention that a regular one does fit allbeit not very snugly. Though it may not fit as perfect as the included cable does it still charge the battery? Do you have to wiggle it around to get it to make contact or is the contact fine but just a bit loose?
Thx! Yes, the other cables will still charge the battery but the connection is very tenuous, a slight bump (and of course this depends on the specific cable as well) can cause it to disconnect.
Thx guys! I've really been enjoying this light. LED's have really progressed a lot in the 8 yrs since I first joined this forum, back then, you would've needed a soda can sized light like the TM11 to produce even half the amount this one does.
