Customer Review for Hot recommend RD tech (ruideng) products of DPS5020, DPS5015,DPS5005, UM25C ,UM34C ,TC66C UM24C at34,DPH5005
107 posts / 0 new
RD tech
RD tech's picture
Last seen: 1 day 15 hours ago
NEW SHARE
RD dual range 100v100A 7in1 OLED Multifunction Tester
[As always, everything is fast and high quality. I recommend to purchase.]
https://www.aliexpress.com/item/32788074155.html
If you have any interest in USB tester or power supply, please contact me
this is my shop on Aliexpress: https://rdtech.aliexpress.com/store/923042
RD tech
RD tech's picture
NEW SHARE
RD AT35 5 digits USB 3.0 color LCD Voltmeter ammeter
[Item arrived in excellent conditions. Works as expected. Here is a comparison between the new model (top) and the old one (bottom)]
https://www.aliexpress.com/item/33022448123.html
RD tech
RD tech's picture
NEW SHARE
RD UM34C Type-C DC voltmeter ammeter
[Cool tester. Checked its charging and wires, it turns out only one wire supports 2a. In general, i’m happy. The seller is well done, everything is packed on conscience.]
https://www.aliexpress.com/item/32880908871.html
RD tech
RD tech's picture
NEW SHARE
RD DPH5005 Buck-boost power supply
[There was no doubt about the correct performance of this device, so that immediately mounted in the backup power supply. I am very pleased with the purchase, i recommend.]
https://www.aliexpress.com/item/32840324731.html
RD tech
RD tech's picture
NEW SHARE
RD LD25 LD35 USB Interface Electronic Load
[Very fast shipping. Item received 7 days after placing order. The load works well. I like the fine current adjustment. The built-in display is handy and accurate enough for testing. I’ve already used it to test voltage drop on USB cables.]
https://www.aliexpress.com/item/32882318330.html
RD tech
RD tech's picture
NEW SHARE
RD UM24C voltmeter ammeter
[Delivery is very fast. The quality is very good, the screen is clear and bright can be seen even in the sun. The version with bt is a convenient program for monitoring on the smartphone. I recommend the seller and the product.]
https://www.aliexpress.com/item/32845522857.html
RD tech
RD tech's picture
NEW SHARE
RD TC66C Type-C PD trigger USB-C Voltmeter ammeter
[The trigger reached severodvinsk in 3 weeks. Packed well. Trigger in box, box in foam. In general, it came safe and sound. Installed on the phone the recommended program. Checked, works fine, bluetooth pairing with the phone. I’m happy. Seller and shop recommend.]
https://www.aliexpress.com/item/32968303350.html
RD tech
RD tech's picture
new share RD DPS3005 DC Step-down Power Supply [I buy the second module, the first was more powerful-5015, but it took another device. As the basis of the amateur power source-the thing is wonderful!]
https://www.aliexpress.com/item/1000004279003.html
RD tech
RD tech's picture
this is the last day of brand shopping day, every product is on discount, the price is lower than ever before.
if you have interest, you can click this link to view more:https://rdtech.aliexpress.com/store/923042/pages/promotion-20190828.html
RD tech
RD tech's picture
NEW SHARE
RD HD35 Electric USB Load
[Before the mo for 12 days. for the organization of such logistics to the seller a big respect! I like the device myself. so i'm happy]
https://www.aliexpress.com/item/32917594486.html
RD tech
RD tech's picture
NEW SHARE
RD DP50V5A Step-down Power Supply
[Order not for the first time. High quality, fast shipment, good packaging. Buy, you will not regret! Seller thanks!]
https://www.aliexpress.com/item/32596330856.html
RD tech
RD tech's picture
new share DPS5020 power supply and its case (non-communication) [Nice body. Recommend]
https://www.aliexpress.com/item/32794029335.html
RD tech
RD tech's picture
NEW SHARE
RD TC66 Type-C Voltmeter ammeter
[As described, works well, no complaints]
jacc
Last seen: 1 week 3 days ago
Hi just curious, is there any USB device out there that can measure the RMS and P-P value of a usb power supply noise, down to the 1mV resolution, without using an expensive oscilloscope? The measurements made by HKJ is always using a high-end oscilloscope. Was wondering is there is other ways to determine the noise of power supplies?
RD tech
RD tech's picture
sorry, we don’t have
RD tech
RD tech's picture
NEW SHARE
RD DP30V5A-L Step-down Power Supply
[I always put 5 to this seller, he is one of everyone who is interested in his products, and does not forget his customers. What can I say about the product is only good, these three understanding converters on the account of the 5th, 6th, 7th previous 4 work stably, perfectly what do I recommend? Sure!!! maybe I'll take a couple more, just in case of emergency.]
https://www.aliexpress.com/item/32639806678.html
RD tech
RD tech's picture
NEW SHARE
[A little more than a month on the road, I received it at UkrPoshta, I ordered it not the first time, everything was clear, I checked it, it works, thanks to the seller, I advise the store ...]
RD tech
RD tech's picture
NEW SHARE
RD AT35 5 digits USB 3.0 color LCD Voltmeter ammeter+HD35
[Nice gadgets. It can be used for measurements] https://www.aliexpress.com/item/33022448123.html
RD tech
RD tech's picture
new share
RD DPS5005 Step-down Power Supply
[Thank. Corresponds to the description. I checked it works. The packaging is great. I recommend. Shipped fast.]
https://www.aliexpress.com/item/1000004290003.html
RD tech
RD tech's picture
new share
RD DPS5015 Step-down Power Supply
[Delivery two weeks. Packed soundly, nothing crumpled on the way. It’s going nowhere easier, two identical cables, where to insert it is signed, you will not confuse. Works good. There are all the necessary protections: temperature, polarity. Various settings are set in the menu. The control is carried out by an encoder, convenient intuitive control. Even a child will understand. Even in this case, there is protection against children, which is turned on by a long press on the encoder knob. For my money, I think a very worthy device. The seller is sociable, quickly responds to SMS, answers all questions. Thank.]
https://www.aliexpress.com/item/32702714880.html
RD tech
RD tech's picture
NEW SHARE
RD DPH5005 digital Power Supply
[I have built my Power Supply with this module and performed extended testing. It works like always, without any problem. It works like a charm. I have already several DPH3205 modules.]
RD tech
RD tech's picture
NEW SHARE
RD DPS5005 step-down Power Supply
[Everything is in place, plus two crocodiles as a gift. The USB module has not yet been tested, and the module itself is working. The packaging is super. From the documentation - a piece of paper with a link to download the software.]
RD tech
RD tech's picture
NEW SHARE
RD AT35 USB 3.0 color LCD Voltmeter ammeter
[Devices delivered quickly. Everything is packed in a foam box, and each device is in a plastic box. Devices are working. I recommend the product and the seller!]
https://www.aliexpress.com/item/32897200670.html
RD tech
RD tech's picture
NEW SHARE
RD UM34C Type-C voltmeter ammeter
[Delivery 25 days. Great tester. Also, communication with smart phone hvia bluetooth, it is generally convenient. I have long wanted this and took it, finally. There are a lot of reviews on YouTube. A worthy gadget.]
RD tech
RD tech's picture
NEW SHARE
RD DPS5020 DC- DC Step-down Power Supply
[Used for input supply 50v 5amp 250w this bulk converter i can get 12v 15amp. Bluetooth power control is very easy. Excellent converter.]
https://www.aliexpress.com/item/32821185351.html
RD tech
RD tech's picture
NEW SHARE
[Fast delivery. Convenient in settings. Measurements are correct.]
RD tech
RD tech's picture
NEW SHARE
RD DPS5005 Communication Constant DC - DC Voltage current Step-down Power Supply
[I was anxious about receiving this, a very useful working instrument. As you see in the pics it’s working fine and it’s very accurate. I’m very satisfied]
RD tech
RD tech's picture
NEW SHARE
RDUM34C USB 3.0 Type-C DC voltmeter ammeter
[Ordered the parcel sent the same day. The seller is responsible immediately packaging is excellent. I went to the center of Ukraine for 28 days. the device is an excellent box for transportation is excellent. I will do a review on my YouTube channel Techno live channel. and recommend.]
RD tech
RD tech's picture
NEW SHARE
RD AT35 USB 3.0 multimeter
[Delivered to Croatia in 2 weeks. USB meter has beautiful display and is very practical and easy to use, comes in a nice plastic box with foam which is great for storing and carrying around. USB load meter is nicely put together, and is also easy to use. I would suggest putting better plastic standoff legs and perhaps knob on a potentiometer. Also foamy box so that it doesnt flap inside. Overall, very nice products for amateurs and pros. I will order more in future. Love this seller and their products.]
RD tech
RD tech's picture
NEW SHARE
RD DPS5020 Constant voltage current DC- DC Step-down communication Power Supply
[I liked the device, for a long time "lay" in "My wishes." So far, it has shaken by about 250 - 280 watts, although it is possible up to 1000 watts. There is no more power supply yet. All the declared parameters work, on the bluetooth of the device it connected without problems to a smartphone and laptop. By USB, too, no problem. A small minus, in my opinion, is a constantly noisy case fan. I can recommend a great device! I ordered the maximum configuration of the DPS5020.]
