We always hope that we can combine more different needs, easy-to-use products to meet the needs of regular consumers and some of individuated needs, this is not an easy thing. Also we have to consider some of the difficulties in mass production.
We glued the head and tube, because some of consumers not really good at DIY or repair work. If not glued them, the driver board may be damaged if it is not careful. That will bring very bad feeling to consumer.
The Anduril UI is very interesting, but in some regular consumers, it is too complicated, that is why we trying to make A & B groups mode to meet different needs.
We really appreciated more discuss to know more about your needs and try to find a better solution.
I’ve seen you post these for 50% off before so I’ve been holding out for that deal again, preferably on AliExpress . Is this the webpage for the H03R RC
Is the charging function part of the driver or a separate board? If it’s part of the driver then I don’t think I want one anymore as I may swap the driver in the future.
Still holding out for 50%+ discount on H03 or H03R on AliExpress
50% off: 1 pcs available everyday for each product.
save $10 for the order $100+
save $15 for the order $150+
save $20 for the order $200+ click here to join
