Here is a photo of the production logo to clarify its close to the one i sent you. (though Sofirn may have adjusted its perimeters & font style a little to make it work for their laser CNC engraving machine:
I got a bit distracted last time I tried to catch up on this thread… but not today. Apologies for the delay in responding to posts.
Yes, the actual behavior is a bit difficult to put into a one-line formula for estimating power usage. When it’s just one channel and it’s running at 100%, it should be 350mA multiplied by the number of chips, like 5. But at lower levels or at mixed tints, it gets more complicated because of analog effects on the rise and fall of each pulse, and code which attempts to correct for that digitally.
It tries to keep the total power usage as close to flat as it can, when changing the tint… but when changing the brightness, it’s still pretty non-linear.
No, it keeps power pretty constant, so maximum brightness is approximately the same regardless of which tint is used.
The default is configured so the highest level can be used safely without overheating, since this item is intended to run for long periods of time without being touched and it has no thermal sensor to use for regulating itself. However, it also allows for a very simple hardware modification to run it even brighter, for those who want more light at the expense of having to be more careful.
Using fewer chips is also slightly more efficient at the same brightness levels, and allows for slightly lower low modes.
Keeping li-ion cells fully charged all the time is one of the fastest ways to reduce their life span. It’s not a good idea to keep li-ion-powered items plugged in all the time with the charge always at 100%, unless you don’t mind having to replace the batteries significantly more often.
It won’t exactly kill cells overnight, but it can definitely reduce the life span from like 5-10 years down to just 1 year.
The pencil trick might not work. I never got it to work on a nanjg driver’s stars, much less on a connection which actually needs to carry a reliable signal during use. But maybe I just need a different pencil.
Yes, it can be reflashed pretty easily. The code is open-source and the driver has programming pads and a standard SOIC8 control chip.
All modes share the same color temperature / tint setting. It can be ramped in almost any mode, by doing a “click, click, hold”.
Candle mode has its own brightness level, configured by holding the button to ramp up/down.
That issue isn’t relevant for the lantern. It doesn’t have thermal regulation, and it doesn’t attempt to do any LVP while it’s off.
Regardless, even if the lantern did those things, the issue was already fixed months ago.
It should be possible in a D4. It even has a good number of LEDs for this purpose, so it can have two of each. It’d basically just need the MCPCB and driver redesigned to have two separate LED- outputs, and the firmware would need some extra code to handle four power channels instead of two. Not sure how hard it would be to fit everything onto a D4-sized driver though; it’d probably be necessary to omit the RGB aux LEDs to make room for the extra power circuitry.
It is probably not over 1000 lumens. By default, probably about 500 or 600 perhaps. It’s hard to measure, due to the unusual beam shape and the black top surface.
The tint, however, is very nice on the middle color temperatures. The warm and cool LEDs mix in a manner which results in a pinkish tint instead of a green tint. This happens because the colorspace is curved, but the mixed tint line is not. The available tints span the pink line here, approximately:
Thanks for the updated Anduril graphic, TK! This thread is difficult to keep up with if you get more than a day or so behind, so I think we can all appreciate your effort there, as well.
:+1: Definitely agree! The firmware Toykeeper developed for the LT1 is my favorite firmware with the perfect modes for any lantern (and for a flashlight even)
We should never underestimate the importance of having adjustable-tint high-CRI momentary bike flasher mode in a lantern. I mean, it would be totally useless without that. How else would we stutter-signal to others while riding down the mountain in our bike-mounted camping tents?
I want multi color color RGB mixing perimeter mounted aux lights with storm mode so we can use it on the Christmas Tree instead of twinkle lights & tinsel!
Do you think there’s enough space in the battery compartment to put a small version of the cheat sheet? Perhaps rolled around the batteries?
This thread is massive and I’ve gotten to the point that I’m either just checking the OP or cruising through the pages looking for significant contributions so my apologies if this has been suggested:
Perhaps a very simplified version of the cheat sheet could be printed somewhere on or in the light on future versions?
For that to work it would require an understanding of the functions, modes, and actions required to modify things but might be helpful for those of us who are forgetful.
Also it wouldn’t surprise me if this UI gets some more use in the future. I can see a D4V3 with warm and cool emitters with tint control. Just default add me to that list.
