Still using my Gen 1 PL47 with Nichia 219B’s on a daily basis with the aid of a copper washer and alternating 2 LG M50 INR 21700 5000mAh/7.3A Flat Top Batteries that I have to charge in my older Xtar VP1 because of recessed Button Tops are not detected in my Xtar Dragon charger.
I use it so much that I change batteries at least once a week and many times, once a day. I use this more than any light in my collection which includes 6 headlamps and I will jsut say 100 other lights . It does use up the 21700’s faster than I expected but it has 4 emitters and I like things bright…developing cataracts doesn’t help either.
I have worn out one Jetbeam headband and currently using an Imalent one. Have 10 more new JetBeam headband (my preferred) and Skilhunt headbands (Skilhunt H03 is second “go to” headlamp). With the minor mods, it has been a GREAT light for anything from taking dog out at night to doing home projects to washing dishes, cleaning, finding stuff I drop, and raiding the Frig at night. BTW, do not use a headlamp if you do not want to see how dirty your house really is!
I have a second Gen 1 PL47 that I haven’t taken out of the box. I tend to buy 2 or more of the lights that I really like so I have a backup, especially if it is a choice 219B sw45(k) 9080 emitter. It is a all part of the sickness.
I am sure the Gen 2 will be great with the improvements Jack has implemented and I wish I had the funds to order one…or two… but I will have to sell more lights before I buy new ones…Too many great light coming out so quickly!
Point is Jack and Fireflies push the envelope and stubble a bit but he and his company have always come though for me. You just have to be patient sometimes!
The armytek plastic headbands are the best headbands I’ve seen. It is extremely easy to use. Just pop in and pop out. No need to fit it through the rubber rings. It fits the PL47.
Is it me, or is the optic in the top photo a bit weird - the bottom two seem fine, but the top 2 are kinda overlapped? (by each other and by the bottom 2?) maybe it’s a trick of the light or something?
Which 21700 battery will suit best in the PL4G2 tube? Can you specify what specification that can drive this quad led smoothly? 20A? 30A? Higher the better? I wondering what battery was used to give the above lumens value…Tq I will appreciated it.
Just want to express my opinion, 4500lumen using xpl hi, if that true, that going to be the brightest,quad led headlamp I have known.
I say the Lishen LR2170SF is the best 21700 cell for the PL47 regardless of emitter option. It is a 15A cell and anything higher current will not make much difference in a quad. The capacity is not too far from LG M50 and Samsung 50E but it is much higher current and the superior discharge curve ensures better performance as the battery drains.
Edit, come to think about it for the 219b version, don’t think you should use the LR2170SF. Might be pushing the 219B too hard. SST-20 version should be fine though. For 219B, either the LG M50 or 50E is safer.
I think, what they meant is tint shift as the led goes through from lower current to higher current. Basically, min amp will give x tint whereas max amp draw will give y tint.
So, tint shift count as you don’t want it overly out from the range tint level itself. Esp 95cri tint, it need to have smaller increment change/shift above or below 95cri level.
Look at xpl, you can use higher current cell bcos you don’t have to worry about tint shift as it. You aim for lumen, hiher current higher lumen then.
When it come to cri 95, here current draw matter most as tint shift happen more severely. Think about the change can be seen.
I am waiting for a Fireflies PL47 Gen2 from Nealsgadgets, and also a pair of 21700 purple Shockli 4550mah from Aliexpress. These Shockli batteries if I’m not mistaken are Lishen LR2170SF remarked, according to the review of this Shockli in Lygte-Info, they are very good. My only concern is that they enter on the tube of the PL47, because its width is 21.7mm, which is quite large, I hope to be lucky and that I can use them.
Nothing much changed compared tot gen1 in my opinion, except the bezel and better assembled inside(no more Broken legs on the optic?).
It also looks like the pocket clip many people complained about is still the same?
Also, champagne color isn’t available anymore,only black…What a shame
I’m gonna pass this one and stay with my gen1
