I got some protected 35Eās and they fit in my 219c and sst20 FW3As but not in my titanium and copper version. That has a different tail switch arrangement.
Absolutely hated the switch in my titanium version, too soft/mushy and no click what so ever. Swapped it with the switch from my aluminum and its perfect now. Nice solid click and you actually have to apply pressure instead of breathing on it to activate. Wonder if the different size plastic nub has anything to do with it?
Mine is strange, I swapped out all the parts, no change
Then I swapped out an aluminum tail cap for the brass, worked perfectly.
So there is something different in the cap.
It works just fine until that last slight turn to get the signal to work then it is like crushed, still works but too little distance in the throw.
Even changed the inner tube, no help. Something in the copper cap.
My other copper FW3 works perfectly
Can not figure it out.
When I first switched the buttons I didnāt notice a difference either, until I removed the retaining ring on the tail of my Ti light. With the button form the aluminum light(little nub) and no ring, itās perfect.
Order placed July 14, Asked for refund about a few times, most recently a month ago from Neal, still no refund.
Really bad service probably the worst I ever had. What can I realistically do? Is there a better way to reach him? I have PMed him a few times, wrote it in email and had trusted him to do the right thing. Is my money lost?
My raw aluminum came in today.
For the first time ever I didnāt even need to remove the tail cap. Works perfectly.
Does have the one step lockout, which is strange since it is new production.
Iām sure you already have, but make sure the ramp and stepped modes arenāt set to the same floor. I think that would make it look like one step lockout.
Got my raw aluminum and Ti-Cu last week. Both with 4000K SST-20.
My impressions:
Raw aluminum - Very impressed
Looks great
Everything in order and works out of the box
High-CRI SST-20 have excellent tint. Noticeably less green even than the 4000K SST-20 in my first-run grey FW3A.
Ti-Cu - Not impressed
Did not work out of the box - head retaining ring was loose, but even after tightening it and tailcap, light still did not work.
Finally got it to work, but only when I pressed the button really hard. Problem identified as being a defective microswitch. The switch had a noticeable click, but only made contact internally when pressed extremely hard. Fixed it by replacing the tailcap PCB and switch with one from an aluminum FW3A. Now it works.
Light came missing the o-ring at the tailcap that is meant to prevent the clip from rotating.
Tint is comparable to the first-run grey 4000K SST-20 FW3A. Still good, but noticeably worse than the tint in the raw aluminum FW3A.
Once I fixed all the problems (which required canabalizing an earlier model FW3A), the light now works fine and looks good.
The FIRST click on lock is the floor setting on RAMP.
The SECOND click on lock is the floor setting on STEP.
For example, for the first click to be moonlight and the second to be Turbo:
From ON, click 4 times
When you get the pulsing light click one time
After the flash, on the pulsing light click as many times as you want to subtract from turbo for the high ceiling - I think there are 150 clicks total, so 10 clicks would be 10% less (or whatever).
After that is done, click to turn the light off, then click to turn back on.
Now Click three times, that gets you into STEP mode.
Click four times. That gets you into low ramp.
At the pulsing light, click 150 times. That sets the floor at Turbo
After the flash, click one time on the pulsing light. that sets the Ceiling at Turbo ā1
After the flash, click as many times as you want to set the number of steps. For this example just click once, there will be no steps.
Now turn off and click 4 times. You are locked. First click will be moon mode.Second click will be Turbo.
This is just an illustration. Real world, when you are in the setup for STEPS, click as many times as you want for brightness, suggest maybe 20 clicks just to see what it does. On the next pulse set the ceiling. Remember, that is MINUS clicks, it starts at full or turbo and works down, try 15-20 clicks to start. The third set of pulses sets the number of steps, do as many as you want.
Hope this helps someone. Took me a while to āgetā it. I never use stepped mode, so I set the floor fairly high. Now I have a usable light from lock, two clicks gets me to maybe the equivalent of med mode.
