Hi!
Mezzol X8R-L. Code not working.
Thank you Fin17!!!
Sorry I’m new to banggood. How does the pre-order work on banggoods. I’m interested in the edc18. Do I pay and wait? Or do they charge you when it ships like amazon? Thanks
Hi Fin, I have some Thorfire tg06s (upgraded version) on order using your code with Banggood. I just tripped over a video that someone has counterfeited that item. Can you advise if there have been any issues you are aware of with Banggood and know that these are authentic? https://www.youtube.com/watch?v=b0URYBzuoGA
[quote=Couchmaster]
Hi Fin, I have some Thorfire tg06s (upgraded version) on order using your code with Banggood. I just tripped over a video that someone has counterfeited that item. Can you advise if there have been any issues you are aware of with this issue and know that these are authentic?
[/quote]
"Thorfire" brand was founded by Banggood, so the flashlights are, of course, original and authentic.
Please rest assured to use.
Perhaps the video compares the old and upgraded versions.
Actually, I have a fake TG06S bought by accident form ebay and the logo and description match the fake one shown here by Couchmaster.
My exclusive coupons for Solar Panels
Hi Fin, below 40W solar panel is in almost the same “undiscounted” price as the 30W panel you shared coupon for.
Is there any chance for discounted price for this 40W Solar Panel?
Thanks Fin! I’ve had good luck with Banggood and have never had an issue with anything I’ve purchased off them before. I didn’t know Banggood founded Thorfire, thanks for that heads up. Like Korkfoto’s point on Ebay above, I just got had for some fake radios off Ebay when I tripped over that vid and I was being cautious.
It leaves me shaking my head why someone would go to the trouble to counterfeit an inexpensive flashlight. Thank you for putting these deals up.
The Amutorch AX4 looks great. Does anyone know how the UI is like? Hope it is not long click to turn off.
Is battery shipment not available route to malaysia? I interest in shockli 26650…
About sofirn sp40, it is added magnet or not? But I really don’t care about it, just wondering…it seem to me a good offer price…
[quote=SKV89] The Amutorch AX4 looks great. Does anyone know how the UI is like? Hope it is not long click to turn off. [/quote]
Switch and mode:
Regular Mode: Onefold click to turn on . Onefold click to dimming:Moon 100 -Low 350 Lumens-Mid 1200 Lumens-High2000 Lumens,Turbo3000 Lumens(quick double-click),Strobe(quick triple-click),When temperature is too high, brightness will down in HIGH and TURBO mode.
Stepless Dimming:it can customize the brightness, long click 0.5 to turn on the light, then long click to increase the stepless brightness, release to lock and remembered the mode. then long click to decrease the stepless brightness. Minimum luminance mode is 25 lumens.
Long press for 1 second to turn it off at any luminance level.
The turbo mode can be activated by quick double click at any luminance level. quick three-click to strobe.Four-click to lock or unlock.
Flashlight protection function explanation:
(1)Mode memory function: if the flashlight is turned on more than 3seconds ,current mode can be memoried.Turn it off and then turn it on ,still the original mode.
if less than 3seconds ,Turn it off and then turn it on ,it goes into the next mode.
(2) Low voltage warning. Battery reverse polarity protection.Control by temperature.
Thanks. I was afraid it would be click and hold to turn-off
Switch and mode:
if less than 3seconds ,Turn it off and then turn it on ,it goes into the next mode.(2) Low voltage warning. Battery reverse polarity protection.Control by temperature.
Is that similar to the AmuTorch AX3?
I can't find a good English translation of the AX3 documentation and wrote my own "documentation":
AmuTorch AX32 operation modes:
A. normal (group) mode:
- single-click to turn on
- another click to advance brightness level
- hold (1 second) to turn offB. ramping (stepless dimming) mode:
-hold (0.5seconds) to start in ramping mode
-hold to increase brightness, a quick follow-up click-hold will decrease brightness
-has mode memory for the brightness in ramping mode
-single-click to turn offshortcuts for both regular & ramping modes:
-double-click to Turbo
-triple-click to Strobe
-single click will go back to previous modeto lock-out:
-from Off, do 4-quick-clicks to Lock-out
-do another 4-quick-clicks to unlock~~~~~~~~~
so basically, the mode the flashlight is in, depends on how the flashlight was turned On:
- single-click from Off will set the flashlight to Normal mode
- hold from Off will set the flashlight to Ramping mode
Ordered S12 and FW3A Cu (separate orders)
Thanks!!!
Best prices with anniversary coupon BG13TH
(expired 09/30)
The code is not working for the UNI-T UT210-E :-(
"Coupon is only used in special collection list and valid on over the specific value"
I don't get it.
I don't get it.
Sorry, wrong link.
This product is duplicated on Banggood site - https://www.banggood.com/search/ut210e.html
Corrected.
Use right link >> UNI-T UT210E
