Thanks Fin! Iāve had good luck with Banggood and have never had an issue with anything Iāve purchased off them before. I didnāt know Banggood founded Thorfire, thanks for that heads up. Like Korkfotoās point on Ebay above, I just got had for some fake radios off Ebay when I tripped over that vid and I was being cautious.
It leaves me shaking my head why someone would go to the trouble to counterfeit an inexpensive flashlight. Thank you for putting these deals up.
[quote=SKV89]
The Amutorch AX4 looks great. Does anyone know how the UI is like? Hope it is not long click to turn off.
[/quote]
Switch and mode:
Regular Mode: Onefold click to turn on . Onefold click to dimming:Moon 100 -Low 350 Lumens-Mid 1200 Lumens-High2000 Lumens,Turbo3000 Lumens(quick double-click),Strobe(quick triple-click),When temperature is too high, brightness will down in HIGH and TURBO mode.
Stepless Dimming:it can customize the brightness, long click 0.5 to turn on the light, then long click to increase the stepless brightness, release to lock and remembered the mode. then long click to decrease the stepless brightness. Minimum luminance mode is 25 lumens.
Long press for 1 second to turn it off at any luminance level.
The turbo mode can be activated by quick double click at any luminance level. quick three-click to strobe.Four-click to lock or unlock.
Flashlight protection function explanation:
(1)Mode memory function: if the flashlight is turned on more than 3seconds ,current mode can be memoried.Turn it off and then turn it on ,still the original mode.
if less than 3seconds ,Turn it off and then turn it on ,it goes into the next mode.
(2) Low voltage warning. Battery reverse polarity protection.Control by temperature.
