Fin17
(Fin17)
September 21, 2019, 6:29am
1072
[quote=SKV89]
The Amutorch AX4 looks great. Does anyone know how the UI is like? Hope it is not long click to turn off.
[/quote]
Switch and mode:
Regular Mode: Onefold click to turn on . Onefold click to dimming:Moon 100 -Low 350 Lumens-Mid 1200 Lumens-High2000 Lumens,Turbo3000 Lumens(quick double-click),Strobe(quick triple-click),When temperature is too high, brightness will down in HIGH and TURBO mode.
Stepless Dimming:it can customize the brightness, long click 0.5 to turn on the light, then long click to increase the stepless brightness, release to lock and remembered the mode. then long click to decrease the stepless brightness. Minimum luminance mode is 25 lumens.
Long press for 1 second to turn it off at any luminance level.
The turbo mode can be activated by quick double click at any luminance level. quick three-click to strobe.Four-click to lock or unlock.
Flashlight protection function explanation:
(1)Mode memory function: if the flashlight is turned on more than 3seconds ,current mode can be memoried.Turn it off and then turn it on ,still the original mode.
if less than 3seconds ,Turn it off and then turn it on ,it goes into the next mode.
(2) Low voltage warning. Battery reverse polarity protection.Control by temperature.
SKV89
(SKV89)
September 21, 2019, 7:10am
1073
Thanks. I was afraid it would be click and hold to turn-off
d_t_a
(d_t_a)
September 21, 2019, 10:57am
1074
Fin17:
[quote=SKV89]
[/quote]
Switch and mode:
Is that similar to the AmuTorch AX3?
I can't find a good English translation of the AX3 documentation and wrote my own "documentation":
AmuTorch AX3
2 operation modes:
A. normal (group) mode:
- single-click to turn on
- another click to advance brightness level
- hold (1 second) to turn off
B. ramping (stepless dimming) mode:
-hold (0.5seconds) to start in ramping mode
-hold to increase brightness, a quick follow-up click-hold will decrease brightness
-has mode memory for the brightness in ramping mode
-single-click to turn off
shortcuts for both regular & ramping modes:
-double-click to Turbo
-triple-click to Strobe
-single click will go back to previous mode
to lock-out:
-from Off, do 4-quick-clicks to Lock-out
-do another 4-quick-clicks to unlock
so basically, the mode the flashlight is in, depends on how the flashlight was turned On:
- single-click from Off will set the flashlight to Normal mode
- hold from Off will set the flashlight to Ramping mode
Unloco
(Unloco)
September 21, 2019, 12:39pm
1075
Ordered S12 and FW3A Cu (separate orders)
Thanks!!!
The code is not working for the UNI-T UT210-E :-(
"Coupon is only used in special collection list and valid on over the specific value"
I don't get it.
Fin17
(Fin17)
September 21, 2019, 6:55pm
1077
Sorry, wrong link.
This product is duplicated on Banggood site -
https://www.banggood.com/search/ut210e.html
Corrected.
Use right link >> UNI-T UT210E
Fin17
(Fin17)
September 22, 2019, 6:47pm
1079
Why buy, and then suffer?
Zeratull
(Zeratull)
September 23, 2019, 7:46pm
1081
Sofirn sp40 ordered yesterday!
hasddie293
(hasddie293)
September 23, 2019, 8:51pm
1082
Question what is the colour temperature CCT of Sofirn SP40 Headlights?? I mean their respective kelvin…
d_t_a
(d_t_a)
September 24, 2019, 4:41am
1083
In Sofirn’s AliExpress store, they have the 5300k, 4000k and 3000k versions.
I think Banggood only has the 5300k version.
1stein
(1stein)
September 24, 2019, 4:57am
1084
Received this one yesterday. Definitely cold white, even beyond 6000K I think.
rb0nd007
(rb0nd007)
September 24, 2019, 5:22am
1085
Thanks, I’m still waiting for mine but good to know. Not bad for the price I guess.
Kilopixel
(Kilopixel)
September 25, 2019, 2:36pm
1088
Is there a quick charg solar panel?
Unfortunately, I have not found anything like that.
Greetings
scosgt
(scosgt)
September 25, 2019, 5:24pm
1090
Got my Tomo M4 today.
VERY cool device!
Fin17
(Fin17)
September 25, 2019, 6:53pm
1091
scosgt -
which batteries do you use with this power bank?
