I just did a quick search. If you can prove me wrong, please do. The first post I found that tried to figure a price point was one by djozz, where he speculated it could be done by $30. But that was quickly followed up by The Miller, who was actively involved on the team at that time, where he said a reasonable price should be around $50. Back then, it was still expected to have only one LED and a Qlite driver with a TP4056 chip added for charging. A newer, advanced driver design didn’t come along until a month after The Miller predicted that price point. I think Den and the team have done well to keep it as low priced as it is, considering how much more has been added to the design since then. :money_mouth_face:
Your words imply that anyone has ever been able to successfully use a Chinese fine-print “manual” without external assistance, either in the form of a magnifying glass, zoomed in picture, or internet search. :smiling_imp:
Cissy told me today that production of batch no. 2 (lot size significantly larger than 500pcs) is about to commence beginning of October with a runtime of about 20 days. So, suppose that the first 500 pcs will be sold out immediately I expect a „supply gap“ or bottleneck of about 3-4 weeks until stock is replenished and goods ready for sale. Now, we‘ll have to wait and see how supply & demand work together.
There are so many features that have been added over the years it’s not even funny.
1. The TP4056 was replaced with a TP5100. Being a 5-18V buck converter, the price difference between both is negligible.
2. We went from probably using 4x XP-Ls of each CCT, to 4x LH351Ds of each CCT, to 8x LH351Ds of each CCT.
3. The driver used uses a more advanced design, and a much more advanced software design, which costs money to implement and test.
4. It includes a USB-C cable.
5. It uses an injection molded custom plastic shade. High quality high efficiency custom shades cost a lot of money to make, especially in smaller quantities.
So, a 10$US bump over the BLF Q8 doesn’t seem unreasonable at all.
I think making lights inexpensively is good without too many compromises, but trying to make it too cheap is extremely dangerous in terms of cost-cutting.
It started out as a single XP-L LED, with a modified 105C Q-Lite driver, in a butchered & modified SkyRay King body then evolved to what we have now, which is still a great price (even at the full non-GB price after) compared to everything else i tested, built, used, etc.
Getting anxious, got in on this and the charger build. Probably will get the wrapped batteries ordered soon. Even ordered a 60w solar panel with discount codes from here lol. Thanks to the build team.
It’s possible to go below a floor and above a ceiling? And somewhere, there will be a printing error and “chold” will be dramatically misunderstood.
A real answer - “click” usually implies press & release, where “hold” implies press & wait. Space in a manual or instruction set is a finite resource. Sometings you have to make the best compromise between an ELI5 answer and the space available.
The min and max levels are determined by the hardware capabilities, while the floor and ceiling are configurable by the user.
About the click / hold terminology, it’s there to eliminate ambiguity. There are four or five different notations floating around, and their phrasing overlaps, which can make things confusing. So I used one with a non-ambiguous starting point.
That is close now to what i can estimate in comparison tests to average household LED bulbs, and using my light sphere with a lux meter comparing the lanterns output to brand name bulbs, is roughly 600 lumens with the tint mix at roughly 4000K for the 5-7135 config on maximum, and around 800 lumens on the same tint setting (4000K average with all eight LEDs running close to equal brightness) on the 7-7135 config. I want to do full run time tests using the best 3500 mAh HC cell sets i have, (using the stepped-output modes but every mode 80% of Max or lower seems to run for days regardless.
I been reading over the manual, most everything looks good so far. (though on the first page along with the manual design-names mentioned, the rest of the BLF LT1 team names should be mentioned/listed to be fair too.
There are some minor parts that need to be edited, (the section where it states the LT1 can be used while charging though the maximum will be reduced, when the lantern is charging with batteries in the lantern it will run on all modes, even maximum, ( but on maximum the lantern load exceeds the charger capacity, thus slowly draining the cells. (When the LT1 is running on the USB-C power alone, then yes the maximum output is reduced, and i recommend not to run it on higher than average 70% output to not overload the 5100 chip.
I have to apologize to everyone, as the last couple weeks i have been a little overloaded with family issues, work, and renovations for my impending forced-house selling in a few months, thus my free time as been really crunched down this past month.
No need to apologize for Life, but I didn’t even notice if you were posting less than usual as we’ve had no questions go unanswered due to your supposed incompetence . Your perseverance is never in doubt thanks to this multi-year project and many people appreciate your efforts, including a lot of folks at Sofirn, I would hope.
Whatever issues you’re dealing with, I think many of us here wish you the best possible outcome.
I have no doubt that this will turn out to be an excellent product because of the following factors, in no particular order:
DBSAR and BLF hardware design team
Sofirn, whose products, in my experience, are beautifully machined, but whose in-house firmware is usually just average
TK and Anduril, arguably the solution to bland, inflexible firmware
There are always risks with new products, but the development process and chosen manufacturer in this case should minimize these risks. I hope that Sofirn sells a million of these and the LT1 becomes a classic like the Colemans and others pictured in previous pages .
