new share
RD DPS5005 Step-down Power Supply
[Thank. Corresponds to the description. I checked it works. The packaging is great. I recommend. Shipped fast.]
https://www.aliexpress.com/item/1000004290003.html
new share
RD DPS5015 Step-down Power Supply
[Delivery two weeks. Packed soundly, nothing crumpled on the way. It’s going nowhere easier, two identical cables, where to insert it is signed, you will not confuse. Works good. There are all the necessary protections: temperature, polarity. Various settings are set in the menu. The control is carried out by an encoder, convenient intuitive control. Even a child will understand. Even in this case, there is protection against children, which is turned on by a long press on the encoder knob. For my money, I think a very worthy device. The seller is sociable, quickly responds to SMS, answers all questions. Thank.]
https://www.aliexpress.com/item/32702714880.html
NEW SHARE
RD DPH5005 digital Power Supply
[I have built my Power Supply with this module and performed extended testing. It works like always, without any problem. It works like a charm. I have already several DPH3205 modules.]
https://www.aliexpress.com/item/32840324731.html
NEW SHARE
RD DPS5005 step-down Power Supply
[Everything is in place, plus two crocodiles as a gift. The USB module has not yet been tested, and the module itself is working. The packaging is super. From the documentation - a piece of paper with a link to download the software.]
NEW SHARE
RD AT35 USB 3.0 color LCD Voltmeter ammeter
[Devices delivered quickly. Everything is packed in a foam box, and each device is in a plastic box. Devices are working. I recommend the product and the seller!]
https://www.aliexpress.com/item/32897200670.html
NEW SHARE
RD UM34C Type-C voltmeter ammeter
[Delivery 25 days. Great tester. Also, communication with smart phone hvia bluetooth, it is generally convenient. I have long wanted this and took it, finally. There are a lot of reviews on YouTube. A worthy gadget.]
https://www.aliexpress.com/item/32880908871.html
NEW SHARE
RD DPS5020 DC- DC Step-down Power Supply
[Used for input supply 50v 5amp 250w this bulk converter i can get 12v 15amp. Bluetooth power control is very easy. Excellent converter.]
https://www.aliexpress.com/item/32821185351.html
NEW SHARE
[Fast delivery. Convenient in settings. Measurements are correct.]
NEW SHARE
RDUM34C USB 3.0 Type-C DC voltmeter ammeter
[Ordered the parcel sent the same day. The seller is responsible immediately packaging is excellent. I went to the center of Ukraine for 28 days. the device is an excellent box for transportation is excellent. I will do a review on my YouTube channel Techno live channel. and recommend.]
NEW SHARE
RD AT35 USB 3.0 multimeter
[Delivered to Croatia in 2 weeks. USB meter has beautiful display and is very practical and easy to use, comes in a nice plastic box with foam which is great for storing and carrying around. USB load meter is nicely put together, and is also easy to use. I would suggest putting better plastic standoff legs and perhaps knob on a potentiometer. Also foamy box so that it doesnt flap inside. Overall, very nice products for amateurs and pros. I will order more in future. Love this seller and their products.]
NEW SHARE
RD DPS5020 Constant voltage current DC- DC Step-down communication Power Supply
[I liked the device, for a long time "lay" in "My wishes." So far, it has shaken by about 250 - 280 watts, although it is possible up to 1000 watts. There is no more power supply yet. All the declared parameters work, on the bluetooth of the device it connected without problems to a smartphone and laptop. By USB, too, no problem. A small minus, in my opinion, is a constantly noisy case fan. I can recommend a great device! I ordered the maximum configuration of the DPS5020.]
Hello RDTech.
I’ve been loving your products, but I’ve been having a small problem.
Using it during chemistry experiments, it has been very useful.
However, being exposed to corrosive vapors on the outside, the outside case screws have started to rust after 9 months.
Could you provide measurements for the screws so I could buy stainless steel or titanium ones?
Thank you.
Edit: This was for the DPS5015 case. Sorry if I did not include it.
Hi friend
thank you so much for your message and your support
could you tell me which case you bough? metal case or aluminium alloy case?
i can provide the instruction, there is screw model name
It is the metal housing case, like on your DPS5015 product page.
NEW SHARE
RD TC66C USB-C Voltmeter ammeter
[This is not the first device from this store and once again everything is almost perfect. To packaging and delivery without claims. The quality is also good. Great device with triggers on board. There is a connection to the PC via micro USB and the ability to upgrade firmware. In general, I am satisfied, I recommend.]
https://www.aliexpress.com/item/32968303350.html
NEW SHARE
RD DP50V5A Constant Voltage current Step-down Programmable Power Supply
[Product Works Perfectly. No Issues so far Found. Fast Shipping. Recommend Seller!]
https://www.aliexpress.com/item/32596330856.html
NEW SHARE
RD DPS3012 constant voltage current step-down power supply
[the goods arrived in 2 weeks as I recommend in the description]
https://www.aliexpress.com/item/32685179404.html
NEW SHARE
RD DPS5020 Constant Voltage current DC- DC Step-down communication Power Supply
[It is functional , I am completely satisfied with the device. Built into the case from the uninterruptible. Delivery is fast, packaging is excellent.]
