I have FW3A, FW3C, FW3T and FW1A
I wish they were FW1A, FW1C, FW1T and FW3A
I really like the FW1A, I guess I’m tired of TIR + multi led flashlights
Very cool flashlight!
But in my FW1A there was no gasket under the glass
maba, I said it on FB, but I’ll say it here, too. Thanks for the pics! Looking forward to this one. I’d really like to see how it compares to the SC64 and S2+.
Gasket?
It should have these parts, stacked in this order:
There is no gasket.
From the pics you posted, your FW1A appears to have the correct parts.
What a great collection!
This leads me to want the FW1A :weary:
Funny, I was going to say it leads me to want a D1 and two Zebralights.
Before that picture, I thought the Unicorn was shorter and narrower. I assumed it was the size of a SC64.
Maybe he means the o-ring between the bezel and lens?
Gasket = o-ring
Yes
Because I took from the backup FW3A, otherwise there was a rattle
These orings are a bit too small and too thick: https://www.fasttech.com/p/1088607
Hi all,
I’ve been introduced here by stephenk from a post on Light Painting Blog.
As a lightpainter, from what I’ve read, I think FW1A is one of the best flashlight to have in our arsenal. Especially because of Andúril and its new momentary strobe feature.
Could someone tell me if the FW1A has the new July update of Andúril firmware?
I read FW3A/1A drivers aren’t updated yet by Lumintop…
Thanks
Hi all,
I read FW3A/1A drivers aren’t updated yet by Lumintop…Thanks
ToyKeeper probably knows, is there any way I can check? I know this version has the two stage lockout, but no factory reset.
I’ve only tried one FW1A, but it has momentary strobes. I think almost all FW3A / FW1A lights are shipping with a version new enough to include that now.
Checking is relatively simple… go to a strobe mode (“click, click, hold” from off), then turn the light off, then go to momentary mode (5 clicks from off) and press the button.
Getting out of momentary mode is a bit inconvenient on FW3A/FW1A though, since it requires disconnecting power. And on this light, that means unscrewing the battery tube pretty far. It’s much easier to exit momentary mode on other lights, like the Emisar D4.
The button placement may also be a consideration when choosing a light. Side switch or tail switch may be more convenient, depending on what you’re doing.
Just received this light today and I absolutely love it. Great beam profile with the SST 20. One advantage of throwy reflector lights I’ve noticed is in tail standing to create diffuse light in a room. The candle mode in anduril is much more effective this way than with optics. Perfect for late night reading.
Welcome to BLF , Frazil .
Ok. So there’s no manual momentary mode yet (your July update), but there is momentary stobes. I can easely live with that. Thanks for your help and your reply!
About the button placement: yup you’re absolutely right. That’s why I rather choose tail switch button flashlight. Because we often attach some sort of light diffuser (e.g. plexiglass) onto the head causing side switch difficult to reach.
Thanks for your quick reply bmengineer. Useful tip.
Welcome to BLF
Thanks a lot
The momentary mode supports regular (steady) output or anything in the strobe group (party strobe, tactical strobe, bike flasher, candle, lightning).
What it doesn’t have is “manual memory”, which makes the regular ramping mode start at the same brightness every time. Instead, it has only “automatic memory”, which uses the last-ramped level. Newer versions allow switching between these two. But that probably isn’t relevant for light painting, and doesn’t affect momentary mode.
You’re right. Thanks for this information.
Cheers
Edit:
FW1A is on the way.
…and I add a FW3A, just because… well I love carrying multiple flashlights.
Finally!
The proper version of this light with so little thermal mass. Only.. Why only OP reflector ? Why no SMO.. ? Beats me to death.. :| Small emitter and OP reflector, makes no sense to me.
I was very much excited when the Lumintop rep on AE told me about the EDC18 that was based on the FW3A - that made me think that Lumintop does consider options and variations.
I've just replied that I'm not too much interested into triples, or multi emitter lights in small formats due to low thermal mass and that I would take a single emitter variant any time,
even at the expense of a shorter cell fueling it, like an 18500/18350 if size constraints are imperative.
Not too many minutes ago just randomly found and watched a review on YT about the FW3A and somewhere in the review, the 21700 and single emitter variations of the FW3A were mentioned - moment of awe!
Ofc, I went straight to Google and typed in Lumintop FW1A - low and behold.. the unexpected (but hoped for.. ) happened! Hurray!
Only when I've got to any of the shops selling them.. there had to be a shortcoming.. ONLY... OP reflector as a choice!.. :| Not nice, really a bummer as far as I'm concerned.
Hopefully Lumintop will consider having an SMO reflector as an option for the FW1A any time soon tho :)
Yay!
Why? I’ve never seen any testing proving that smooth reflectors give noticeably more throw, and the lead to more beam artifacts. With the smaller LEDs used here, this light already is quite throwy.
Lumintop actually considered both options, I suggested they pick OP if they had to choose just one.
