NIGHTWATCH NI40 SBT-90-GEN2
Thanks for posting that. The SBT90.2 is most impressive for sure. Seems like Nightwatch wants to test every single emitter in that host. Fortunately, it’s a really good host and I really like the heat shedding.
The SBT90.2 draws a lot of current, so I guess the NI40 will get hot very quickly unless there’s a stepdown in place. Which leads us to another intriguing topic: What UI and what regulation is in place? Is there a time-triggered stepdown and/or a thermal stepdown? In the latter case, at what temperature threshold will the stepdown be triggered? Does the NI40 with SBT90.2 start on maximum like the Nightwatch NS53A (XHP50.2 3V 6.500K), presented here?
Do you have any lumen/intensity numbers?
Where on earth did you get your hands on a SBT90.2
I see they wrote the sbt90g2 led itself is expensive than the flashlight host Ni40 :open_mouth: idk if that true…hmm
If this beast can reach 1.2km to 1.5km and have able on turbo for atleast 3mins, I will buy it! :smiling_imp:
The “tunnel” beam seem to me a lot wider than the current the wider Xhp50.2, dedome which really makes it great!
I had vary in mind, only Niwalker and 1st to introduce sbt90g2. I wonder where are the rest brand, I bet some of them are really good in making a throw light become a performances! I mean, pushing the light development towrd the edge of its limits. As like before, we see convoy and astrolux. I not sayin it bad, but what i trying to say is, competition is where the best light is born. Hehe. Peace!! :wink:
$34.00 USD each X 3 plus $30.00 USD for DHL shipping….
Is that from the Chinese company lantend?
I emailed them and plan to get a couple.
The head is nowhere big enough to hit 1.2km. Need something the size of an FT03 for that. Probably will be a bit under 1km.
Yep wendy@lantend.com
To give an idea for comparison, the Acebeam X65 mini is rated at 492,000 candela = 1,403 meters throw
Oh acebeam k75 was a sbt90 g2…opppss :disappointed: . nvr seen it. I often to neglect “expensive” section… but, image above clear showing a different, based on the “tunnel” beamshot. K75 has smaller hotspot than ni40.
Updates?
at first it look like the Ni40 outthrow the X65 mini, but nope
look at the brightness on the house, the X65 mini is clearly winner
I’d like to see more beamshots of this light if possible.
someone tell me if the LED only the 90.2 might be able to fit in the emisar d1s would love that combo :stuck_out_tongue: or let’s hope emisar d1s-v2 is coming with something like this led?
Beamshot please…
Please find some professional beamshots made by Bluzie (TLF admin) here:
Gheez! What a light, 4000 lumen ansi on turbo. Thank a lot…
Seems like the 40T is perfect for this LED…now Hank has no excuse not to put it in the Noctigon K1 :smiley:
Nagonka:
MOON: 50lm
Low: 570lm
Mid: 1050lm
High: 1900lm
Turbo: 4950lm
Turbo after 30s: ~ 4000lm
Turbo pulls out about 22A from a 40T
Also said a full Shockli 5500 does only 3750 :frowning:
Someone else said it reaches 70.6°C after 1.5 minutes. There was no step down even after 3 minutes :open_mouth:
