Sofirn C01S SST-20 4.000K 95CRI / Low-High version available again!
I put a FET driver in one of my C01S if anyone is interested:
Might be able to squeeze out a bit more output with further tweaks.
Nice work!
I’d be VERY interested to own such a pocket rocket.
Good luck with that, Mtn has been out of that driver and most of their other ones forever.
I just ordered mine last week…
Sorry, you are right. They have two 12mm FET drivers. One is in stock and the other isn’t. I must have missed that one. Last time I looked at them they were out of stock, but it’s been a while.
C01S Black is available, with diffuser.
https://www.ebay.com/itm/Sofirn-C01S-AAA-LED-Flashlight-Mini-Keychain-Light-100-Lumens-Free-Diffuser-/383114172244?nordt=true
or choose pack of two
https://www.ebay.com/itm/Sofirn-2PCS-C01S-AAA-LED-Flashlight-Torch-Light-Mini-Keychain-Size-100-Lumens-/383145079630?nordt=true
links do not work
try these …
diffusor
description states
Twist the head will change brightness levels Low 5 Lumens and High 100 Lumens
2 pk
2 pk description states
Simple 2 Modes: High: 100 lm(1h, 25min), low: 3 lm (25h, 15min). Twist the light head to switch the mode (high - low)
so which are these lo hi or hi lo?
Sounds like low-high, but perhaps Sofirn can confirm?
I recently received a high > low version, ordered from Amazon since I was already putting in another order.
I would normally strongly dislike this mode order, but I wanted a small light to carry at work for unexpected inspection needs. Basically, all I need for that is 50-100 lumens as conveniently accessible as possible. I tried just using the light on the expensive phone they issued me, but it doesn’t cut it.
The C01s is perfect for this need.
The tint looks ok - definitely better than the Fenix E05 I was using before, and high CRI. There is ring around the beam when staring at a white wall, but so far I don’t notice it in use.
The only flaw is that over time the moment comes that when trying to twist the light off, instead the bezel comes off. I know it is blasphemy, but the bezel threads need a drop of glue.
Seems to be more common to the BLF version. Have there been reports of this problem for the anodized version also? Thus far I was lucky with them.
Why is low 5 lumens now?
Just screw on the bezel first as hard as you can, then screw the head on.
No, you should not do that, already tried that, the bezel will reach so far over the pill that when twisting the light on, the bezel will touch the battery tube before the driver does, so it will not light anymore.
I’ve had this happen on both of mine. Stuck on in FET until I got pliers to get pill out. Can’t tighten body too much or else bezel will give in first like you say. I sort of agree but would never be the first to mention it
Interesting, I don’t have that issue with mine. You could try filing the bezel down a bit.
I thought about filing the bezel too, but I prefer a bit of glue in the threads instead.
Good to know. I will wait to loctite mine until I decide if I want to try any other emitters in it.
Asked via eBay if they were default low. Was told that they are default high
Edit: Asked if they had an ETA on default low and they gave me this answer:
“my friend, in November, C01S will have this version. (there be a version in default low mode)”
Please check my new interest check for a small-size batch of C01R (red light keychain light):
I asked about the posibility of new low/high batch yesterday and here’s the answer:
