550kcd+ Emisar D1Sv2 coming this month!
53 posts / 0 new
Petelele
Petelele's picture
According to Hank:
Quote:
The D1SV2 should be released before the end of this month.
Yes, it should reach 400kcd+ with the Osram W2, and 550kcd+ with the Osram W1.
Quote:
Yes please, those are the prototype testing values, not theoretical values.
Vraag niet hoe 't kan, maar profiteer ervan.
Edited by: Petelele on 10/09/2019 - 04:41
Skylight
Skylight's picture
Last seen: 6 hours 59 min ago
Sounds like it will have a 70mm head. I hope for nice body colors, a short tube and some neutral white options as well. Thumbs Up
My Youtube channel: Alllightson Reviews
My 7th Old lumens contest build: Matainvoy ML18SBuilt video
My reviews: Sofirn SP31 V2.0Nightwatch NI40 StalkerSofirn C8F 21700Brinyte WT01 ApolloSofirn SD05
My Youtube video-reviews: Brinyte WT01 Apollo, Sofirn SD05
nobody
Last seen: 18 hours 42 min ago
Sounds great!
mbp
Last seen: 2 days 8 hours ago
Do they make those Osram LEDs in anything but 6500k? I don’t know that I’ve ever seen any neutral or warm tints but I’m not very experienced with the emitter.
Gerrit
Last seen: 43 min 6 sec ago
tthat’s good news
djozz
djozz's picture
Last seen: 8 hours 3 min ago
There are a few tint bins but the range is limited, I think 5400K is the lowest. Kaidomain managed to source a batch of the lower CCT tint-bins for the PM1 White Flat version (2mm2). link
hasddie293
hasddie293's picture
Last seen: 4 hours 34 min ago
Is there anyone can translate 550kcd equal to distance in meters or km…?
Awesome news. I always look osram led beam in youtube. Beam look very2 intense…
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
gkushev
Last seen: 1 day 18 hours ago
If I’m not mistaken a bit less than 1.5 km.
djozz
djozz's picture
550 kcd = 550,000 cd = defined as the brightness at 1meter distance
Throw distance is defined as the distance at which the brightness is reduced to 0.25 cd (=about moonlight illumination)
So at throw distance the bightness has decreased 550,000 × 4 = 2,200,000 times compared to 1 meter distance
Brightness decreases with the square of the distance, so we need to take the root of 2,200,000 to arrive at the throw distance, this is 1483 meter.
Petelele
Petelele's picture
throw=sqrt(cd/.25)
so 1483.23969742m
SKV89
Last seen: 11 min 14 sec ago
But the lower temperature tint bins are above the BBL unfotunately. Has anyone tried the Kaidomain one to see if it is more greenish?
mrheosuper
Last seen: 4 weeks 2 hours ago
0.5 or 1 lux is more pratical, 0.25 lux is barely visible in most cases
Forgot my pen
HONDARIDER
HONDARIDER's picture
Last seen: 2 days 15 hours ago
I will definitely be looking at those when they are released. I have a decent collection of Emisar’s.
Tubercle
Last seen: 2 hours 16 min ago
What will be the lumen output? Around 1500 lumens? Gonna be a pencil beam.
Petelele
Petelele's picture
My guess would be 800-1000 lumens, but that is very generous. the chip is rated for 800 lumens with a max of 1000 lumens
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 10 min ago
This is true, but the standard specs use 0.25 lux. So people stick with that, to make numbers comparable across the entire industry.
Yes, it will probably be the pencil-est of pencil beams. At 550 kcd and maybe 800 to 1000 lumens, that’s 550 to 687 cd/lm. So the beam will probably be even tighter than the BLF GT. It has slightly more cd/lm and the reflector is smaller, so we can expect this one to perform extremely well at a distance but won’t really be useful up close.
Basically, it’s optimized specifically to be as “pencil beam” as possible.
bmengineer
bmengineer's picture
Last seen: 1 hour 15 min ago
If this ends up being offered with an XHP35 Hi I might be interested, even though I really don’t need another thrower.
Find all my reviews of flashlights and more gear at www.bmengineer.com
Flashaholics
Flashaholics's picture
Last seen: 1 week 1 day ago
It’d be interesting to see how far the K75 shone until it recorded 0.01 lux. I’ve seen it hit white buildings at well over 3000m
My 4K Lumen Whore Reviews (MS18, X70, MS12, DX80, X80-GT, X45vn etc) - https://www.youtube.com/c/FLASHAHOLICS_GB
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 3 hours 13 min ago
Would be great to see the light offered with XP-L HI and SST-40 as well for more options in beam profile and tint. A CC driver hitting ~5-6A at max would be perfect for those as well.
hasddie293
djozz wrote:
550 kcd = 550,000 cd = defined as the brightness at 1meter distance Throw distance is defined as the distance at which the brightness is reduced to 0.25 cd (=about moonlight illumination) So at throw distance the bightness has decreased 550,000 × 4 = 2,200,000 times compared to 1 meter distance Brightness decreases with the square of the distance, so we need to take the root of 2,200,000 to arrive at the throw distance, this is 1483 meter.
That my new lesson today. Tq, appreciated it.
  • KCD to distance(meter or km)
  • beam profile which is candela/lumen(cd/lm) in this case, cd is really intense while lumen is moderate, thus generating a pencil-look-like beam
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
Th558
Th558's picture
Last seen: 5 hours 4 min ago
Hank said the head is 70mm. Doesn’t 550kcd seem a bit less for that size?
ToyKeeper
ToyKeeper's picture
Yes, the metric used to quantify beam shape is “cd/lm”. Here’s a rough guide for what that means.
Assuming XP-L HI in each light (except D18 and D1S V2), Emisar’s products go in this order from most floody to most throwy:
  • light bulb: ~0.1 cd/lm
  • D4: ~4 cd/lm, ~4300 lm
  • D18: ~4 cd/lm, ~14000 lm
  • D4S: ~11 cd/lm, ~4500 lm
  • D1: ~33 cd/lm, ~1300 lm
  • D1S: ~100 cd/lm, ~1300 lm
  • D1S V2: ~600 cd/lm?, ~800 lm? (TBD)
  • laser: ~10000 cd/lm
For general-purpose “EDC” style use, people mostly like items in the range of roughly 3 to 30 cd/lm, with the D4S’s 11 cd/lm being a very versatile balance. The D4S is a bit large though, so I’d really like something D4-sized or smaller with a single emitter and a ~10 to ~15 cd/lm beam.
I generally use the D4 most because it’s the smallest and has a clip, but the D4S has my favorite beam of the bunch. The D1 is also handy since in 18350 form it’s small enough to forget about in my purse until I need it, and it’s throwy enough for almost anything I ever need.
With D1S and D1S V2, they’re extremely good at what they do, and are unusually compact for the amount of throw they achieve… but it’s rare that I ever need or want that much throw. For people who do need it though, it’ll basically leave almost everything else in the dust, especially for the price.
Th558
Th558's picture
He also said there are no plans fora SBT90 Gen2 version
blueb8llz
Last seen: 3 days 3 hours ago
550 kcd sounds right. I have a 72mm head with a oslon black and it only does 550kcd.
But I wish he would give us a rear clicky. Side clicky are nice if it was a high output thrower. But for a pencil beam dedicated thrower, a rear switch is better imo.
BlueSwordM
BlueSwordM's picture
Last seen: 2 days 5 hours ago
Rear clickies have two disadvantages: restricted UI choice and internal switch resistance.
That 1st point is obvious.
That 2nd point is having a good enough switch to support high current is quite expensive. Well, compared to an electronic switch anyway.
There’s something less obvious though: standardization for Emisar lights.
By only using e-switches, it makes it easier for them in terms of making stuff, and less overall costs.
SKV89
I’m sure there will be a Skylumen version with the SBT90.2
hasddie293
If we look at LED price comparison e.g, sst40.sst20, nichia, xhp35, xhp50.2, xhp70.2, osram WF, XPL…vs the SBT90.2 Shocked Shocked
When it come to about, making profit…everything must be lower price as possible as cheaper as it is!
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
Th558
Th558's picture
Well he can just price it higher. I’ll happily pay even $85 for it. The performance of that thing is crazy..slightly more throw than an XHP35 HI with over double the output.
bmengineer
blueb8llz wrote:
550 kcd sounds right. I have a 72mm head with a oslon black and it only does 550kcd. But I wish he would give us a rear clicky. Side clicky are nice if it was a high output thrower. But for a pencil beam dedicated thrower, a rear switch is better imo.
So you want a FW1A GT?
contactcr
Last seen: 2 hours 2 min ago
Needs a fixed aspheric lens option! How cool would that be
ToyKeeper
ToyKeeper's picture
For a light like this, regulated at ~5A or ~6A, the switch resistance is a much smaller factor than it would be in something like a D4 or D18. It may still be difficult to do well, but it’d be a lot easier than with really high-powered lights.
As far as UI goes, I added tail-clicky support two years ago. Most UI functions are on a side e-switch, and the tail provides momentary activation at the last-ramped level. It works fine, from what I’ve heard, and does exactly what people usually want the tail switch to do in a thrower.
